How many miles do you guys have on your trucks ?
#676
Should have bought a Doge?
Originally Posted by enduringexplorer
2003 7.3PSD with 240k. Falling apart POS. Should have bought a Dodge. Well, maybe it's payback for a lifetime of flawless Ford products. Up until now, all of my fords have been great.
#680
#682
#683
2003 f250 fx4 sbsc bfg 305 70 16 flowmaster 40 dual pipes
55,000
so far i have had these problems
fly wheel broke
ring gear broken
starter broken
front stabilizer shock leaking
oil cooler leaking
leather seats cracked
6 disc changer broken
rear sliding window lock broken
rear brakes shoes/pads and rotors
front brakes rotors and pads
locking hubs seized three times
vacuum lost
overheating/ still a problem
idle sensor? replaced
new coils and boots
WHAT THE &*^$ is wrong with this truck
55,000
fly wheel broke
ring gear broken
starter broken
oil cooler leaking
vacuum lost
new coils and boots
#687
Work Truck 99 F350 5.4 auto 2wd
308,000 miles
complete list of repairs
3 alt's
1 set of plugs
4 brake jobs, rotors ever other brake job
4 set of tires
1 set ball joints
1 headlight switch
2 pass side mirrors (drivers fault)
1 trans at 307K
1 pcv tube
1 fan relay
1 set of shocks
1 pass tie rod end
The body is remarkable tight and rattle free. The HD vinal seat has 1 small rip in it. The windshield has a small star in it (original) The paint still looks like new, exept for some small scraches. 1 dent in pass side rear corner (see pass mirror).
Will I buy another superduty to replace this one. You bet your ---. but at this rate I might not need one.
308,000 miles
3 alt's
1 set of plugs
4 set of tires
1 set ball joints
1 headlight switch
1 trans at 307K
1 pcv tube
1 fan relay
1 set of shocks
1 pass tie rod end
#689
308,000 miles
3 alt's
1 set of plugs
4 set of tires
1 set ball joints
1 headlight switch
1 trans at 307K
1 pcv tube
1 fan relay
1 set of shocks
1 pass tie rod end
308,000 miles
3 alt's
1 set of plugs
4 set of tires
1 set ball joints
1 headlight switch
1 trans at 307K
1 pcv tube
1 fan relay
1 set of shocks
1 pass tie rod end
