Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southwest Region > Arizona Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Arizona Chapter Join Chapter, Leader: Bill W
  #1 (permalink)
Old 11-28-2003, 11:26 PM
tomfords tomfords is offline
Garage is empty, add now
tomfords is starting off with a positive reputation.
Question head light assembly on 1993 f 150
How do you remove a 1993 f 150 headlight assembly? Unlike the newer headlights there are no tabs but phillip screw heads that do not turn..
  #2 (permalink)
Old 01-20-2004, 09:34 PM
bosshoss bosshoss is offline
bosshoss is starting off with a positive reputation.
If i remember, first remove the two cross point screws on top of the headlight grill assy. Then remove the two 10mm nuts on the backside of the headlight assy. They are hard to get to sometimes. One is in the corner. If you are removeing the right head light, you need to remove the battery and the tray i think. its been awhile. Good luck. DP in NC.
__________________
Dave Powell
Tags
1993, 93, assembly, f0rd, f150, ford, grill, grille, head, headlight, ligth, removal, remove, removing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
