Help !!! with wiring question on 2000 Excursion.... - Ford Truck Enthusiasts Forums
Old 05-05-2000, 01:14 PM
John_Mac John_Mac is offline
John_Mac is starting off with a positive reputation.
Old 08-22-2000, 08:26 PM
69excursion69 69excursion69 is offline
69excursion69 is starting off with a positive reputation.
[font size="1" color="#FF0000"]LAST EDITED ON 22-Aug-00 AT 08:28 PM (EST)[/font][p]Customer access wiring on the right side of the steering column, 5 wires (red, black, white, blue, blue/white) all tagged customer access wiring. 4 wires, all but the blue/white in the loom above the power dist box, underhood. A 10a fuse marked cust access ign. feed in fuse box.
Any ideas what these are, where they go, can I use them to power acc's?
Thanks......Kevin
Old 08-23-2000, 12:22 PM
ExcursionPSD ExcursionPSD is offline
ExcursionPSD is gaining momentum as a positive member of FTE.
Kevin
Four of the wires (2 pair) are prerun thru the firewall and not connected to anything on either side, so you don't have to mess with making holes in the firewall, for things like gauges into the engine compartment.
The fifth wire (I don't know the color) is connected to that customer access fuse circuit. I would make sure it has a fues in it, turn the ignition to on, and then use a tester or voltmeter, with one side on a good ground, to find this 'hot' wire. It could be used for any accessory (depending on the wire gauge and fusing)
2000 Excursion Limited born 11/99 4x4 Toreador Red ext./gray int. 7.3PSD, 3.73LS, Skidplates, Pwr/Htd TeleMirrors, 6CDchanger, HtdBuckets, LT265/75R16D AT, Ford Wraparound deflector, PSDV8 badging, RoofMarkerLights
wheels 1973 - 1979 F-100 & Larger F-Series Trucks 7 04-13-2004 01:08 AM
is this common 1987 - 1996 F150 & Larger F-Series Trucks 3 11-12-2002 02:38 AM
Wheelbase 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-14-2002 10:06 AM
Overheating 1973 - 1979 F-100 & Larger F-Series Trucks 8 03-11-2001 11:13 PM
Tags
2000, 73, ac, access, block, circuit, clutch, customer, excrusion, excursion, ford, fuse, limited, red, wires, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
