1990-E -350 van.. what is it??
I have a 1990 ford e-350 van with a E-40-D trans with overdrive..My question is what is plugged in on top of my rearend(differential housing).It has a two wireplug.The piece is held in by one bolt.The bottom half is a magnet about the size of a thimble.I need to know the name so I can order one as I broke it...thanks rvdsr....
speed sensor.
Thanks for reply.I ordered a speed sensor & they sent me one that goes on the trans.Between the speedo cable & the trans. tail shaft.It has the same kind of plug(two wire).Do they work together?Also where can I get one for the rear end.?From a dealer,or somewere on line?? rvdsr...
scubaguy2011
03-27-2015 05:26 AM
AerostarDad
01-13-2015 12:05 AM
HardScrabble
08-19-2009 08:06 AM
