Flathead performance parts - Ford Truck Enthusiasts Forums
Old 11-26-2003, 04:16 PM
Fordhog Fordhog is offline
Fordhog is starting off with a positive reputation.
Question Flathead performance parts
I'm planning on a full out building of a 49 flathead. If you,ve seen my other posts you know I've been himhawing about wether to build my flathead or shoehorn a diesel into my 1 1/2 ton but I've decided to build the flathead to peak performance and give it a whirl. I keep seeing sites praising the availability of performance parts for the flathead but they must be invisible . I'm looking for a good place to find cams, pistons, possibly a supercharger, all the good stuff that the wife looses sleep over .Any help would be greatly appriciated.
Old 11-26-2003, 07:44 PM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is gaining momentum as a positive member of FTE.
Fordhog, wise decision. I sure wish I had gone that route. Since I don't have a flathead in my 1/2 ton, I can't be of much help, but many here can. Just threw away an old catalogue I think by Joe Smith company who had flathead performance parts.
Old 11-27-2003, 10:44 AM
46fordtruck's Avatar
46fordtruck 46fordtruck is offline
46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.
Flathead Jack's...all performance flatty stuff http://www.flatheadjack.com
Motor City Flathead
13624 STOWELL ROAD
DUNDEE, MI 48131
(734) 529-3363
Speedway Motor's
http://speedwaymotors.com/Default.asp?wc=true
Also, Edelbrock still lists heads and intakes in their new catalogs.
There is a place making superchargers for flatty's...I think Motor City was working on a fuel injection system for flatheads as well. Flathead jack is a very good place, they know what they are doing.
Old 11-27-2003, 02:46 PM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Gary gave you a good list to work thru. I'd start with Red Hamilton of Red's Headers. He's been around the business a long time and is super to work with. If he doesn't have what you need, he'll know where to send you.
http://www.reds-headers.com/default.htm
Hot Rod and Custom Supply in Cape Coral, FL is another good one for availability of a wide range of supplies.
http://www.rodncustom.com/
From what I've seen and heard, Flathead Jack is one of the most expensive, but he does have some stuff that nobody else does if you can work with him.
Old 11-27-2003, 04:32 PM
f100guy f100guy is offline
f100guy is starting off with a positive reputation.
edelbrock sells heads for the flathead as well as a dual carb intake
Old 12-01-2003, 09:10 PM
Thanks a lot guys! That will definetly get me started on my way. I'll keep you posted and we'll see how my sick mind and flatheads get along, could be interesting.
Old 12-04-2003, 07:26 PM
52f1 52f1 is offline
52f1 is starting off with a positive reputation.
A good place to go for info on flatheads are 2 other chat groups that are for flatheads only. the first and best is www.fordbarn.com/earlyv8/forum03/ The second is http://groups.msn.com/FordFlathead19...pgmarket=en-us ( Keep'em Fat and Flat ) 52-F1
Old 12-10-2003, 09:28 AM
dogdays dogdays is offline
dogdays is starting off with a positive reputation.
Ross Pistons has pistons for the flathead any bore any stroke.
SCAT has brand new modern connecting rods.
There is also a 4.25" stroke crank being produced, probably by CAT.
Cams get with Isky
Heads, Edelbrock and Offenhauser.
Manifolds, Fenton replicas by Patrick's
Ignition, I think Mallory has a new distributor for the flathead.
What more could yo ask???
R.
Old 01-20-2004, 09:41 PM
bagodonuts bagodonuts is offline
bagodonuts is starting off with a positive reputation.
Yo,Fordhog I've used MSD'sdistributor and ignition on a '50 flatty,absolutely fantastic,by the way,flat-o-matic makes great kits to use a c-4 auto or t-5 stick behind that slab head (flat-o.com) I think the guy runni'n flat-o-matic is Gene and he's real easy to talk to on the phone if ya want info.
Old 01-26-2004, 07:20 PM
OilLeaks's Avatar
OilLeaks OilLeaks is offline
OilLeaks is starting off with a positive reputation.
Just to add two cents to the other suggestions...Egge Machine Co. at www.egge.com is another source for flathead parts. I'll also second the earlier opinion of starting with Reds Headers...very knowledgable guy and good to work with. Yet another source for some parts is eBay...lots of flathead parts up for auction - buyer beware of course - and be advised that most of the "bargains" have gone away as people tend to bid the price up (sometimes way past what they should) but you can still find some hard to find historic manifolds and carb cores for not bad money.
Flatheads forever - keep em running!
Old 10-27-2008, 08:50 PM
flatheadJohnA flatheadJohnA is offline
flatheadJohnA is starting off with a positive reputation.
Hello this is a link to a supercharger for a flatty.
Magna Charger, Inc. - Flathead Ford Supercharger Systems & Accessories
Hope this helps -John
Old 12-04-2008, 05:59 AM
needhelp49 needhelp49 is offline
needhelp49 is gaining momentum as a positive member of FTE.
speedway motors has a good selection cams heads storker kits intakes and the prices dont seem to bad
Old 12-16-2008, 12:36 PM
nflfreak43's Avatar
nflfreak43 nflfreak43 is offline
nflfreak43 has a good reputation on FTE.nflfreak43 has a good reputation on FTE.
oh wow i didnt realize there was all this performance things for a flathead. i just got one and me and a friend is gonna build it.
Old 12-16-2008, 02:21 PM
bmc69 bmc69 is offline
bmc69 is starting off with a positive reputation.
I would add Flathead Jack's and Wilcap/Sharp to the list..the others I deal with have already been listed.
Alos, one of our regular suppliers for all makes of performance parts, Mad Dog Racing, has added some flattie items to their mix.
1948 flathead vs. 1948 flathead kens65fb 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 08-17-2016 02:33 PM
New 402 c.i. Flathead ALBUQ F-1 1948 - 1956 F1, F100 & Larger F-Series Trucks 31 02-27-2013 06:55 PM
Flathead vs. 302 Old Iron 68X 1947 and Older Ford Trucks 18 05-13-2012 11:31 AM
49-53 Flathead V8 restoringmy46 Flathead V8 & Flathead 6 5 12-16-2004 10:23 PM
column to floor shift 51 F1 flathead revinbluejeans 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 09-02-2003 10:48 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
city, club, ebay, enthusiasts, flat, flathead, flatomatic, ford, head, heads, motor, oregon, parts, performance, racing, supercharger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
