Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 11-25-2003, 06:13 PM
CHACH CHACH is offline
Garage is empty, add now
CHACH is starting off with a positive reputation.
Propane injection ???
Has anyone installed one of these in our kind of motor ?? Can it be done and what sort of results would normally be expected ???
Chach
  #2 (permalink)
Old 11-26-2003, 02:54 PM
Greentree Greentree is offline
Greentree is starting off with a positive reputation.
Converting a diesel engine to burn propane really doesn't make any sense. But just for argument's sake, let's see what would be involved.
In any internal combustion engine the fuel must start to burn in the cylinder at precisely the right moment. Because of compression ignition, this eliminates introducing gaseous propane into the intake manifold like they do with spark ignition motors. As the piston began to rise, the heat of compression would immediately cause the charge to detonate. There's no way to control when the burn begins.
This implies mechanically injecting liquid propane into the cylinder in the same manner as diesel fuel. Hmm, injecting liquid propane at high pressure: I wonder what kind of pump could do that, especially since the lubricating properties of liquid propane are probably zilch. Once the liquid propane is in the cylinder, it must vaporize. The evaporting propane would absorb a considerable amount of heat and ...
Do you see there's no overriding advantage to such a setup? We spend extra money on diesel engines because it burns a fuel that has a higher heat content per cc, is easier to refine, and costs less (at least it's supposed to!). That translates to savings. Figuring out how to do it with propane as a fuel is a lot of pain for no gain compared to a spark ignition motor.
  #3 (permalink)
Old 11-26-2003, 03:20 PM
Well heck. I guess you're referring to a propane boost system such as that at http://www.dieselperformanceproducts.com/home.html.
My misunderstanding.
  #4 (permalink)
Old 11-26-2003, 05:36 PM
beretzs beretzs is offline
beretzs is starting off with a positive reputation.
I was trackin with you CHACH. I think alot of fellers do it. Try it, I need someone to be a guinea pig for it. Alot of guys claim it is the way to go, even when combined with a turbo. Scotty
__________________
Semper Fi, Scotty
1987 Ford F350 4X4, 6.9 Liter Banks sidewinder, 4" straight piped, C6 Tranny, 4.56's, 6 inch skyjacker and 37" Super Swampers
1977 Jeep CJ5, 4" lift, 33's and a built AMC 304 4.10's F-R with a Detroit Locker in the rear and a Powe
  #5 (permalink)
Old 11-26-2003, 06:35 PM
I stopped into my local (no)discount performance shop amd they showed me a bully-dog setup that they wanted like $600 and thats w/o a tank. You have to build/buy your on tank. And they said it gave 80 hp ... If I could find it cheaper,maybe direct, is 80 hp worth it ???
Chach
  #6 (permalink)
Old 11-26-2003, 09:57 PM
Spectramac's Avatar
Spectramac Spectramac is offline
Spectramac is gaining momentum as a positive member of FTE.Spectramac is gaining momentum as a positive member of FTE.
I've heard the only prerequisit is a turbo charged diesel. I'd like to try it someday.
__________________
Malcolm
97 Explorer 5.0 AWD
87 F250 6.9 CTS turbo
Tags
1977, 2003, 304, 50, amc, ford, inject, injection, jeep, propane
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
