heater core replacement 1986 e-150 - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 11-25-2003, 01:54 PM
geson geson is offline
geson is starting off with a positive reputation.
steam coming from vents and anti-freeze on floor tell me I need a core...anyone replace the core on 1986 e-150 before?...I have a compuer box in the way...how do I get to it?....how pricy is replacement?...thanks
Old 11-25-2003, 02:08 PM
Bigles Bigles is offline
Bigles is starting off with a positive reputation.
Done several on the E 350's . They are very simple and can be done without removing the dog box. Be sure and replace the foam padding around the core.
Old 11-25-2003, 02:34 PM
RH F-350 RH F-350 is offline
RH F-350 is starting off with a positive reputation.
Replaced a couple on a 1990 E-250 pretty much straight forward.Watch them plastic clips they brake easy.
Old 11-25-2003, 02:39 PM
After you disconnect the battery, drain the radiator a little to get the level below the core. Remove the hoses from the core. On the inside, you should find 5 mounting screws around the box. Remove them.
Then remove the assembly. Remove the case seal from the face of the case & remove the retainer. Slide the core & seal from the case.
That is all there is to it!!
Now reverse the procedure. Leave the highest hose loose as you refill the radiator, to bleed the system.
You should be good as new!!!!!!
how to replace a heater core in a 1998 F 150 brandon olson 1997 - 2003 F150 13 12-30-2013 08:02 AM
Anyone have done change heater core on E250? Super Econoline 1968-2013 Full Size Vans 5 03-06-2013 02:51 AM
Heater Core Replacement JasonBrod 1997 - 2003 F150 5 10-04-2012 02:05 PM
1985 f250 heater core f150rd 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 12-19-2011 07:55 AM
How do i flush a heater core 91Van Cooling, Heating, Ventilation & A/C 18 04-06-2007 11:33 PM
Tags
150, 1986, 1994, 2000, case, change, core, e150, ford, heater, radiator, repair, replace, replacement, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
