Whats wrong with my horn?
Ok, I was not to sure where to put this, but here goes; When I push my horn it dont go "honk", instead it makes a clicking noise under my dash like by the glove box. The horn did work when I first got the truck but it just stoped one day. Then one day I pushed it and it worked and stoped. Has not worked since and thats been like 2 months ago. I really would like to fix it so that every part on the truck works. I get really mad when stuff dont work like it should.
adam
adam
The horn would be right behind the grille at the front of the truck. disconnect the 1 wire to it and test for voltage while someone is pressing on the horn switch
The horn switch is at the steering column (that works re. clicking under the dash)The horn relay should be under the dash. There is a bank of relays on a square plastic panel not unlike the fuse panel. probably by the glove box.
Do you know exactly what the horn looks like? I have not noticed one, so I'm not exactly sure on what they look like. Do you know wich side of the truck its on passenger, drivers? So first thing I should check is the horn at the grill, then the horn switch in the steering coloum then the relay? Does anybody got any specs on where the relay is under the dash and what it looks like?
adam
adam
