I hate squeeky windshield wipers!
Next to squeeky anything, I hate squeeky windshield wipers more. Even when they are brand new and there is plenty of h2O on the glass, I invariably end up listening to the wipers skip across my windshield. I must be cursed because it happens in nearly every one of my cars. AAAARRRRRRRGGGGGGG!
What causes this annoyance? I can't figure it out.
This is actually a truck tech question but it is also common to a lot of the vehicles we have in our shops. There isn't any other forum around that is better for it anyway
The problem with squeaky wipers is the alignment of the blade to the windshield. Misalignment can occur due to wear or damage over the years. You can bend the wiper arm with a wrench to change the blade alignment. If the arm attachment point is worn all you can do is replace it. You may also need to replace the blade holder if it is worn. As far as which way to bend the arm I can't give you any guidance there except to say try to keep the blade perpendicular to the glass..
Hey I like the way you guys think so I'll throw out my wiper problem. I have a area about the size of a dinner plate that the wiper skips. Yes it is right in front of my face. I put on new arms and it still does it. It is almost like there is a dip in my windshield. I have cleaned the glass but it did not help. When there is rain it is slightly smeared in this area. It is clean above, below, and on both sides.
on
1 Post
Originally posted by Bargod
I've heard good things about the teflon ones, I am going to get some next time I change wipers. Has anyone used these before?
-Matt
