Whos got the highest mileage?
i have a 91 xl ext aerostar . just turned 190,450. miles. original 4.0 engine. rebuilt A4LD tranny at 135 thou.miles. runs strong !! the kids call it "the green bean" as it is all dark green. this is the only vehicle i've kept this long with this much mileage,. i'm looking forward to 200 tho miles. gotta have a goal!! rick
1990 aerostar 2wd ext; 196,000
original engine & tranny
replaced;
headgasket (Ford warranty at 12,000 miles)
sway bar link
fuel pump (twice) & relay (once - but it was not bad)
radiator
AC died a long time ago - but not needed in the Pacific NW
radio
tail light assembly (shopping cart collision)
headlamps, taillights, thermostats, alternators, battery, brakes & tires, shocks, passenger side power window switch (3 times), air filters, oil & oil filters.
Original owner, this vehicle has finally proven economical after almost 14 years of operation.
(~ 11 cents per mile + gas & insurance)
nickname: the Conestoga
replaced;
sway bar link
radiator
radio
My '90 XLT 3.0 has 143,000. Original engine, 2nd tranny since we've owned it. Had to replace head gaskets, intake manifold gaskets, intake plenum gasket, timing cover gasket, oil pan gasket, water pump, alternator, both idle pullies, fan and clutch, all radiator hoses under the hood. Original exhaust but it is cut off after the O2 sensor. Going to put a cheap muffler on it this weekend until I can afford to fabricate an exhaust.
