Blower Motor Replacement. - Ford Truck Enthusiasts Forums
Old 11-23-2003, 08:51 PM
wiznewski wiznewski is offline
wiznewski is starting off with a positive reputation.
1976 F150 with AC need to replace blower motor.
Need advise on how to do job.
Is this a simple fix or a real head ache.
Is all the work done from under the dash. I do not see the blower motor or mounting fasteners on the firewall.
Thanks for the help
Old 11-23-2003, 09:13 PM
BigBully BigBully is offline
BigBully is starting off with a positive reputation.
All work is done under the dash, Do a search this Question has been addressed many times in the Past and there is detailed instructions in the past posts.
89 F150 blower motor switch is funky johnnyfoodstamp 1987 - 1996 F150 & Larger F-Series Trucks 4 12-06-2016 07:15 AM
Blower not working aero993 Cooling, Heating, Ventilation & A/C 0 06-12-2016 10:43 PM
Heater A/C Blower motor Chris McCarthy 6.4L Power Stroke Diesel 1 06-02-2016 06:36 PM
07 Explorer Eddie Bauer - Blower Works Intermittently wpannone Explorer, Sport Trac, Mountaineer & Aviator 2 05-09-2016 09:56 PM
battery drain problem -fan/blower help 78crewcabjohn Excursion - King of SUVs 8 02-23-2015 05:28 PM
Tags
1976, 1979, blower, early, f100, f150, ford, guide, location, motor, older, replace, replacement, school, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
