Correct spark plug color? - Ford Truck Enthusiasts Forums
Old 11-23-2003, 03:49 PM
ck85abc ck85abc is offline
ck85abc is starting off with a positive reputation.
When I tested my spark plugs I got the below.
There two area's were the spark arc's across: Brown and whites. Has white speckles and wereever it is not white it is brown. About 50-60% white.
The walls going down to the inside of the plug: All black.
The inside of the plug but not the walls: All brown.
How is my engine running? Do I need to chagne anything? If so what?
I really wish I knew some technical terms here so I did not have to describe stuff like that
Old 11-23-2003, 04:36 PM
fordman428's Avatar
fordman428 fordman428 is offline
fordman428 is starting off with a positive reputation.
well when the end up the plug is brown it means its running good, if its black it means its getting to much fuel, if its whit it is to lean not enough fuel, sounds like u may need to adjust the carb give it a little more fuel not much cuz as u stated there is brown on them and that means its running well but sense theres white on it, that means its to lean so adjust your carb to give it a little more gas and you should be alright, good luck
Old 11-23-2003, 04:39 PM
jwtaylor jwtaylor is offline
jwtaylor is starting off with a positive reputation.
your mention of brown sounds normal. The white speckles and white electrode could mean the plug is too hot. Make sure the plug you are using is the correct heat range. Other causes could be overadvanced ignition timing, lean air/fuel mixture, vacuum leak (intake manifold), sticky valves or insufficient cooling.
Is the engine efi or carb? Have you changed anything lately such as the intake or carb? Are the correct spark plugs being used? Have you messed with the timing? Anything out of the ordinary happening? later
Old 11-24-2003, 02:57 PM
Thanks for the usefull information. Ill look into all that stuff. I thought that the tip of the plug was not acually were you were supposed to be looking though? More like down at the base of the plug?
spark plugs clean, but sweating gass/oil? william16339 1973 - 1979 F-100 & Larger F-Series Trucks 9 09-12-2014 07:50 AM
Brown Booted 5.4 - Spark Plug Replacement aortizexcursion 2004 - 2008 F150 3 07-21-2014 07:23 PM
Brown Booted 5.4 - Spark Plug Replacement aortizexcursion Modular V8 (4.6L, 5.4L) 0 07-19-2014 03:24 AM
460 running to lean? 7.3 down 1987 - 1996 F150 & Larger F-Series Trucks 4 12-16-2013 12:24 PM
Favorite 73-79 2-tone color combo JohnT 1973 - 1979 F-100 & Larger F-Series Trucks 29 06-08-2004 12:28 PM
Tags
coler, color, correct, f150, plug, proper, spark, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
