Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Escape V6 Spark Plugs
Old 11-23-2003, 11:52 AM
hanovver28's Avatar
hanovver28
hanovver28 is offline
According to the owners manual, the spark plugs are to be changed at 100,000 miles. I bought a set, thinking I could do it myself. How hard could it be; right? wellllll, I can't find the rear plugs. Can anyone help me out? I'm not a gymnast, so if being a contortionist is a prerequisite to doing this, I'll have to refer this job to someone more limber.
Old 11-24-2003, 09:20 AM
gasman6674's Avatar
gasman6674
gasman6674 is offline
On every side saddle V6 I have ever owned you either had to rock the motor forward or work from under the vehicle. I have not looked under my 04 yet. When the time come I will probably wimp out if I still own it. Might want to get a Haynes Manual it should say for sure.
Old 12-02-2003, 08:09 PM
escapie's Avatar
escapie
escapie is offline
hanovver28, I whish I had better news for you but changing the RH side plugs is big undertaking. According the the actual "FORD" mechanics service maual, you have to remove the upper intake manifold to access those plugs, LoL.... The real job is first detaching all the perifriall parts to get to remove the maifold! If your really ambisious, let me know and I will send you the manual proceedures. Good Luck!
Old 12-09-2003, 02:41 PM
PrPlayboy's Avatar
PrPlayboy
PrPlayboy is offline
ahhhh wires,...... vacume lines...........
You should be able to do it your self but if you think you may forget where something goes tape a note to it. I've used zip ties before. Got a big set from walmart with different colors so wasting them was not a problem I put one color on a hose and another zip tie of the same color where it came off from.
Old 01-01-2004, 08:16 AM
Escaped's Avatar
Escaped
Escaped is offline
Question To change or not to change (the spark plugs)
I recently purchased a 2003 Ford Escape. When I realized they weren't kidding about 18 MPG in town, I thought I would buy some Bosch Platinum+4 Spark Plugs to try and imprtove this. When I got home and couldn't even find the spark plug wires I was a bit dismayed. I would be interested in receiving the FORD Mechanics instructions, Escapie. I am not afraid to remove the intake, but I would like to know I am following the correct procedure. Thanks.
Old 01-14-2004, 08:36 PM
southerntrax4x4's Avatar
southerntrax4x4
southerntrax4x4 is offline
don't use bosch!!! i have seen nothing but bad things happen when people put them in fords. trust me stick with motorcraft.
Old 01-14-2004, 11:45 PM
tsdrallyer's Avatar
tsdrallyer
tsdrallyer is offline
Oh, yes. Stick with Motorcraft plugs and oil filters. They are the best for your Ford, period.
ymirr
04-06-2017 07:42 PM
HelenB
05-17-2016 04:38 PM
tyrantsparky
01-28-2014 09:21 AM
getsch58
06-22-2006 09:00 AM
Hellbore
35
06-11-2006 01:40 AM
Quick Reply: Escape V6 Spark Plugs
