AOD to C6 swap - Ford Truck Enthusiasts Forums
AOD to C6 swap
Old 11-23-2003, 02:55 AM
mcanik's Avatar
mcanik mcanik is offline
mcanik is starting off with a positive reputation.
Thumbs up AOD to C6 swap
Hi all. This is going to happen, but before it does, I could use a little bit of professional input on how smooth of a transition this will be.
I have the whole donor truck, a 1988 F150 4X4 complete setup with a C6. The truck I am installing it in is a 1990 F150 4X4 currently with an almost dead AOD.
I will definitely inspect the C6 before installation. should I also replace the clutch packs? Put a shift kit in?
Any help is good help.
Dan.
c6 in f150? mean green 91 1987 - 1996 F150 & Larger F-Series Trucks 8 04-25-2011 07:35 AM
C6 to AOD Swap dreadinger Clutch, Transmission, Differential, Axle & Transfer Case 3 06-20-2008 09:54 PM
C6 to AOD Swap witdog2020 Clutch, Transmission, Differential, Axle & Transfer Case 5 01-09-2006 08:47 AM
C6/AOD option in Bronco's? gov2mod 1978 - 1996 Big Bronco 3 11-14-2005 11:07 AM
94 f-150 5.0 aode to c-6 shane1 Clutch, Transmission, Differential, Axle & Transfer Case 1 01-31-2005 03:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
