Glow Plug Relay?
Glow Plug Relay?
Hey fellows. I need to find out which relay is the glow plug relay. Their is 2 relays up around the fuel filter to the left facing the truck on my 2001 F-250 powerstroke. Which one is that relay. The one in front higher up or the one behind it lower. Can yall explain the troubleshooting of that relay. I think I trouble shot it right but dont really know for sure. Having a hard time cranking. It will crank and fire but not like it used to. Longer cranking than it used to. thanks for any info. cuttr28
glow plugs are under the valve cover, relay is mounted to the left front area of the engine, looking at it from in front of the truck.
If it is working, it will click when the key is first turned, so have someone turn the key, with the door shut, to avoid the ding ding, and listen for a click. That is the glow plug relay.
Theo
This is the picture showing locations on a 94-98
Not my truck, I got the picture in an email, so I cannot give the correct credit..
Theo
Thanks....I was pretty sure that was the right one. I read some information on line about the relay and how to check it. There are two main bolt lugs that are supposed to both be hot when the glow plug light is on. I see 12v on the always hot side, but don't see anything on the other side when the key is turned on. I do however hear and feel the relay click. Am I doing something wrong?
If you hear it click, and there is no voltage showing on the cold post, the contacts are broken - try shorting out the terminal posts, carefully with something conductive, when you have the need to start. If the relay is functioning, but broken, shorting out the terminals will put power to the plugs, and will make it start easier, if the plugs are ok. If not work needs doing.
Theo
Theo
Hey fellows, sorry I'm just now getting back on here, but thanx for the info on glow plug relay. Was'nt the relay after all. i think i got some bad diesel. It started cranking normal, or like it used to instead of taking 3 to 4 seconds to crank. Thanx again, this is a great website. cuttr
I was able to fix my problem. The relay was definitely bad. When I tried to pull the nut from one of the terminals, the whold terminal broke free.
Also, just for everyone's information. On '99 and newer trucks, there are two relays. The glow plug relay is the one in the rear closest to the firewall. Also, I took some other advice that I read in some other threads and called my local International dealer for the part. I was able to get the exact relay (same part number and everything) for $25.22 instead of $108 at the Ford dealer.
you can go to NAPA and get the replacement if you need it runnin, Part number GPR110 or something along those lines.
Let me know if you need more documentation on how to get the old one off and put the new one on.
Also there is a little test you can do to find out if your GPR is bad.
I believe the link and pic below will help you, definitly go w/ the stancor.
Welcome to guzzle's Stancor GPR replacement Mod Web Page
reply to smokin for help
thanks smokin for the help on my truck as soon as i charged batteries and warmed up the gpr it has started since but i suspect it may be bad or going that way..... the picture showed the relay located on top of engine next to manifold sort of it looks like a voltage regulater to me and there is 2 of them side by side? sorry i didnt get back sooner i check e mails once a day usually.
