2006 F250 codes
Old 03-23-2013, 08:54 AM
farmall63's Avatar
farmall63
farmall63 is offline
2006 F250 codes
i have a 2006 F250 with a 120 thousand miles 2 weeks ago. I blew a high pressure oil pump so I had that replace along with a new oil cooler and a heavy duty egr cooler he also upgraded the fitting. I pull a goose neck trailer with it, Yesterday the check engine light came on. I checked the codes and this what came up code p0470, p0232 and p1379. It also threw out the code u1900 I disconnected the battery to reset and it has not come back on so far. what is this telling me? also I put two new batteries in. thanks
Old 03-23-2013, 09:29 AM
amdriven2liv's Avatar
amdriven2liv
amdriven2liv is offline
I'm hitting easy street
P0470 Exhaust Pressure Sensor "A" Circuit
P0232 Fuel Pump Secondary Circuit High
P1379 Fuel Injector Control Module System Voltage High
U1900 CAN Communication Bus Fault - Receive Error
Looks to be electrical. Check all the battery connections, positive and negative. Clean and reconnect. Check for chafing around FICM harness. (as best you can, tight area in there.
Any way to check readings? Like a Scangauge II or something?
Old 03-23-2013, 09:35 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is offline
Well, these codes seem unrelated to me, except they are all "voltage high" errors.
P0470- EBP "A" circuit high
P0232- Fuel pump secondary circuit high
P1379- FICM volts high
U1900- unspecified but likely a likely data error of some type.
Sounds like something shorted for a second. I would look over all the wiring that was disturbed during the recent repairs, and check the alternator for a/c output on the main lead. Battery power (v) is limited to the current state of charge for the batteries and shouldn't be a problem so I'm thinking vRef (normally 5v) is shorting to battery power somewhere or charging system output was too high.
Just thinking out loud here, maybe some of the more experienced guys will be along with a better answer.
Old 03-23-2013, 09:36 AM
farmall63's Avatar
farmall63
I will be installing the torqe app this weekend
Old 03-23-2013, 04:59 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Check and clean grounds would also be a good thing to do.
Wire chafing could be a problem.
Sean
Old 03-24-2013, 08:45 AM
farmall63's Avatar
farmall63
thanks I will check the grounds and make Shure no wires are chaffing. I love this truck it pulls trailers like there is nothing behind it
Cletus98
18
08-15-2016 11:39 AM
droidtn
1983 - 2012 Ranger & B-Series
02-02-2014 01:54 PM
sdsd
12-01-2011 05:13 AM
FI460
01-12-2011 06:48 AM
35l911
09-14-2010 08:58 PM
Quick Reply: 2006 F250 codes
