Maximum towing length? - Ford Truck Enthusiasts Forums
Old 11-21-2003, 01:41 PM
Shake-N-Bake's Avatar
Shake-N-Bake Shake-N-Bake is offline
Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.
I've looked up the towing laws for my state (Arizona) and it says I can tow up to 65'. 2 trailers are ok as long as the first trailer has brakes and the second trailer is under 3000 lbs. (If not, then both trailers need to be less than 28.5' long and towed with a large rig).
My question is:
I interpret the 65' length as Total Trailer Length.
My friend interprets it as Total Vehicle Length (including truck)
A coworker tows a 5th wheel with a small trailer for his sand buggy behind. I'm thinking about doing the same thing with my fifth wheel (only towing a boat instead of a buggy). This coworker says the trailer length is the only thing they measure, and with fifth wheels....the measurement starts at the part of the trailer that is behind the rear bumper of the pickup (NOT from the very front of the fifth wheel). Does anybody know if this is correct? I've e-mailed the DOT here and asked this same question but haven't received an answer yet. Of course, if they do ever answer my question....I'm going to print it out and keep it inside my truck in case I get pulled over.
I appreaciate any information you may have to share on this issue. Thanks.
Old 11-21-2003, 06:45 PM
rclarke rclarke is offline
rclarke is gaining momentum as a positive member of FTE.
maximum length in this chart is the total length of the combination of vehicles.
http://www.rvsafety.com/state.htm
Arizona allows a total combined length of 65 feet.
Old 11-25-2003, 10:03 AM
Thank you for the clarification. Looks like I'll be about 3 feet over length then. Bummer. I HAD to go and buy the longest fifth wheel I could find.........
Old 08-12-2007, 02:43 AM
bigsub bigsub is offline
bigsub is starting off with a positive reputation.
[QUOTE=rclarke]maximum length in this chart is the total length of the combination of vehicles.
QUOTE]
that link is dead. Anybody have an updated on? I'm curious particularly for colorado and also , nevada, utah, california and wyoming.
Arizona allows a total combined length of 65 feet.[/
Old 08-12-2007, 03:20 PM
Here's another link to a towing chart.
http://www.wecamp2.com/size.html
Old 08-19-2007, 08:20 PM
bigredtruckmi's Avatar
bigredtruckmi bigredtruckmi is offline
bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.
Old 08-23-2007, 11:47 AM
USMC Diesel's Avatar
USMC Diesel USMC Diesel is offline
USMC Diesel is starting off with a positive reputation.
California
If the trailer is under 30' you can go to 75 ' Combined length
If over 30' 65'
Old 09-02-2007, 12:22 AM
emptyd emptyd is offline
emptyd is starting off with a positive reputation.
Quote:
Originally Posted by bigredtruckmi
Anyone know what is indicated in the "Reciprocity" column of this chart? I know what the word means, but does it relate to honoring other states rules, or other countries rules? Rules about driver's license classifications, towing specifications? What?
Old 09-02-2007, 05:42 AM
mistakenID mistakenID is offline
mistakenID is gaining momentum as a positive member of FTE.mistakenID is gaining momentum as a positive member of FTE.
Generally if a state has Reciprocity with other states, you will be legal in those other states. That is assuming you are legal in your home state with regards to license and towing laws.
It also means that if you get a ticket in a reciprocal state, it will go on your driving record in your home state.
5th wheel towing Luckyc1423 2017 Super Duty 0 10-29-2016 01:49 PM
Rear Suspension Help/Advice Please CurtSD 1999 to 2016 Super Duty 2 08-27-2015 09:32 AM
Question about towing wrongway01 2015+ F150 11 08-19-2015 01:01 PM
Towing as a business/car hauling/fifth wheel, this is long!!!! 78bigunns Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 20 11-10-2005 11:28 AM
F250 Trailer Towing Capacity Floater 6.0L Power Stroke Diesel 8 03-25-2004 09:29 AM
Tags
5th, camper, hauling, legal, length, longest, longets, maximum, nebraska, pulled, pulling, rv, towing, trailer, wheel, wwwtowingworldcom
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
