302 to 400 engine swap?? - Ford Truck Enthusiasts Forums
Old 11-20-2003, 09:43 PM
aseclub.net aseclub.net is offline
aseclub.net is starting off with a positive reputation.
is it posible to swap a 400 ltd motor in my 77 f-150 2wd 302 truck? how much work would it take? could i use my same transmission out of the 302? or should i just rebuild the 302?
Old 11-20-2003, 09:55 PM
Txquadhunter24's Avatar
Txquadhunter24 Txquadhunter24 is offline
Txquadhunter24 is starting off with a positive reputation.
You could do it, You'll need Frame mounts. The tranny behind your 302 won't work the 400 uses the Big block bolt pattern. If your wanting to up size your motor the 351w will be a bolt in swap.
Old 11-20-2003, 09:57 PM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Your tranny will not mate up. A 300-6 would also mate with your tranny. The 300-6 has more torque for a truck application.
A 400 from a truck would be a better choice than a car because the brackets would be for a truck.
Old 11-21-2003, 04:03 PM
Supercab Supercab is offline
Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.
Cool
If you have a 302 in the truck now you can use the same frame mounts for the 400, but you won't be able to use the mercs mounts, you'll have to buy them for your year truck application.
Can you use the trans from the merc? the one behind your 302 will not bolt up.
351m/302 engine and transmission swap. roy123 Engine Swaps 5 01-26-2007 09:57 PM
Bellhousing Swap?????? 80-F-250 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 06-05-2006 03:31 AM
400 to 302 swap Ford_Six 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 12-07-2002 10:32 PM
302 to 400 swap jerry p 1973 - 1979 F-100 & Larger F-Series Trucks 2 08-17-2002 01:54 PM
swapping in a 302 can it be done? holl 1973 - 1979 F-100 & Larger F-Series Trucks 10 04-25-2001 11:05 PM
Tags
302, 400, 91, bolt, engine, ford, motor, same, swap, swapping, trans, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
