87 302..Smog, Exhaust holes in back of heads - Ford Truck Enthusiasts Forums
Old 11-20-2003, 04:57 PM
Tattoo Matt Tattoo Matt is offline
Tattoo Matt is starting off with a positive reputation.
I have 87 302 5.0...I took all the smog stuff off...in the back of the heads there was a exhuast toob coming from each head ..I took those off,cut the toob then welded it together...now i have a leek from one side..My ? is does anyone know the best way to fix this...can't i just take a pipe threaded bolt and plug it with that ...and if so does anyone know what sizt it is? and I can't find it at the ford dealership..
Thanks Tattoo Matt
Old 11-20-2003, 06:24 PM
71swissaqua's Avatar
71swissaqua 71swissaqua is offline
71swissaqua is starting off with a positive reputation.
Stop by any good head and block shop and ask them. I don't know the exact name of it but it will thread in almost like a helicoil to block the hole and will have threads on the inside to bolt your accessories in. They should know what you are talking about and if you ask real nice will probably just give you a couple
Clint
Old 11-20-2003, 08:18 PM
I don't understand what accessories your talking about..
Thanks for the reply..Tattoo Matt
Old 11-20-2003, 09:36 PM
90f150moneypit 90f150moneypit is offline
90f150moneypit is starting off with a positive reputation.
I think he means the accessories on the front. But that won't be necessary since your working on the rear of the heads.
He is right about going to a machine shop though. You can also go to your local dealer and get them. They are called thermactor port plugs, they only cost a couple bucks.
Old 11-20-2003, 09:52 PM
Trick Flow makes a plug for their heads but works for factory iron as well.
Check here.
Old 11-21-2003, 09:12 AM
What I meant was, since the heads are reversible from side to side you are pluging the holes used to bolt on your alternator or power-steering pump they are just on the back side of the engine
Clint
Old 11-28-2003, 10:31 PM
mooktank mooktank is offline
mooktank is starting off with a positive reputation.
i think he means the smog ports.
Thinking about buying a 1998 F150 with 4.2L V6 WalMart101 3.8 & 4.2L V6 3 08-18-2016 11:27 AM
Uhaul flunkies screwed up my brake light wiring! Akzep69 1987 - 1996 F150 & Larger F-Series Trucks 2 06-05-2015 01:26 PM
Car Tattoos NiteEditionF150 General NON-Automotive Conversation 13 03-25-2012 03:01 AM
ford tattoo? 81fordf-250 The Next Generation 42 02-17-2008 09:03 PM
Governor 2001 Ranger Tattoo626 Ranger & B-Series 60 08-20-2006 04:10 PM
Tags
302, 460, 50, back, block, engine, exhaust, ford, head, holes, offs, plug, plugs, port, smog, thermactor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
