Bigger tires for my Ranger - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 11-20-2003, 04:21 PM
Knightmair Knightmair is offline
Knightmair is starting off with a positive reputation.
What's the tallest, widest tire that I can put on my 2000 Ford Ranger XLT....2 wheel drive. Because I want bigger tires on it. Also recomending the best lift kit for a 2wd Ranger would helpful as well...3 inch lift at most.
Old 11-20-2003, 06:22 PM
ctfuzzy's Avatar
ctfuzzy ctfuzzy is offline
ctfuzzy is starting off with a positive reputation.
Re: Bigger tires for my Ranger
Quote:
Hi Knightmair, Welcome to FTE!!
If you'll do a quick search on that topic you'll get more answers than you could ever possibly use . .
. . or want
Old 11-20-2003, 06:37 PM
SSN621 SSN621 is offline
SSN621 is starting off with a positive reputation.
quick search where?
Old 11-20-2003, 08:30 PM
stRanger706 stRanger706 is offline
stRanger706 is starting off with a positive reputation.
i would say a 255/70R15 would be the biggest youd want to go, with no lift. it'll rub a tad at full lock, but thats it. there arent too many lifts available for our trucks. fabtech, cst, and camburg are the only ones that make a real lift kit. fabtech makes a 3" spindle lift for around $400 i think. check it out at www.performancelifts.com
Old 11-20-2003, 08:50 PM
ctfuzzy's Avatar
Quote:
Originally posted by SSN621
quick search where?
A small row of blue buttons near the top of this web page. Third from the right. Brobably right below a blinking banner ad.
Seriously, it's worth taking a look at all the options and variables before you lay out the bucks.
Old 11-20-2003, 10:48 PM
Will that 3" spindle lift kit fit my 3.0L V6 2wd.....cause its not an Edge and it shows the Edge with that kit.
Old 11-21-2003, 01:18 AM
if u click on ford midsize lifts...its right there, 98-02 non-edge rangers 3" spindle lift
Old 11-21-2003, 12:41 PM
Ok...with this lift...will i have to get any other parts in a larger size to compensate for the lift?
Need help w lift/tires ChazCol Brakes, Steering, Suspension, Tires, & Wheels 0 02-10-2015 03:57 PM
Want to lift my 90 f250. Post a pic of your lifted truck justin90gsx 1987 - 1996 F150 & Larger F-Series Trucks 5 03-21-2011 09:39 AM
How much fender can I trim? none2 Offroad & 4x4 22 11-27-2007 09:34 PM
2002 Ford Ranger Tires garciaranger Ranger & B-Series 2 10-23-2006 09:15 PM
Are new shocks needed for a 2in lift on front of ranger? 88broncII Ranger & B-Series 21 06-25-2006 11:14 AM
Tags
2000, 2002, 2wheel, bigger, biggest, drive, ford, guide, inch, lift, lifted, put, ranger, tire, tires, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
