My 97 psd has a 4.10 rear end, at 55 its at about 2000 rpm, at 70 its at 2500rpm. what is the safest rpm range to operate it at so i dont blow my motor up or somthing.
Originally posted by cookie88 RPM wise you are G to G. It'll turn 3400 rpm all day every day.
Hi Guys. When my truck get to about 3300 the boost will drop to about 15 lbs and the engine just lays down want rev any higher. Is that the Map triping the defueling mode or is the PCM limited?
Boost is about 21 lbs right before it drops.
CH
Chip it.
I installed the Diablo chip and in the 78 hp mode the boost gets over 25 lbs.
I installed a pop off pressure valve that is calibrated to 24 lbs. in the MAP line so the SES light doesn't come on.
I read somewhere that overboosting 25 lbs + isn't good on the heads?
I've got the SCMT 80h and have seen 27psi pulling a 78' Bronco from OK. back to CO. Yes, my light came on...but I couldn't feel any power loss. The light goes out after 1-3min.
As cookie88 said, installing any of the devices that fool the MAP sensor will not change the amount of boost your truck produces, but it will reduce the amount your MAP sensor sees, so it won't defuel when you get to the 22psi level.
It is a very good question, what is the safe operating range. Crawling around in the woods how low is to low and how high can it be reved without hurting it while it tries to fing the bottom of a mud hole and theres no time to shift?
There shouldn't be a too low crawling around in low gear, unless it's so cold out the exhaust temps fall below 275 or so, but even then the chances of anything being damaged are pretty remote.
Like I said, the factory rev limiter is going to catch it at ~3400 rpm, and that is well below what it takes to hurt a PSD. It won't start floating valves until the 4000 rpm neighborhood.
