Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-19-2003, 10:43 AM
Diesel_Owner's_Wife Diesel_Owner's_Wife is offline
Garage is empty, add now
Diesel_Owner's_Wife is starting off with a positive reputation.
Location of Voltage Regulator?
We have an '89 7.3L (<65,000 miles) that wouldn't start the other day because the bateries were run down. It has two batteries, only a few months old. My husband hooked up the battery charger, of course, and proceeded to look at the belts. He found the alternator one was loose and obviously worn. He used the volt meter on the alternator and found it was putting out only about 8 volts -- needs to be at least 13. He would like to use the volt meter on the voltage regulator, but a quick look didn't turn up the location. We need the truck as we are building a house ourselves, but it has been pouring down rain here in western Washington and he is sick, so we haven't spent time working on the truck (or the house). If someone could pinpoint the location of the voltage regulator, it would make it a quick job to check the output. Then we'd have more info before we just start buying parts. Thanks a lot! -Carol
  #2 (permalink)
Old 11-19-2003, 11:57 AM
mattydiesel mattydiesel is offline
mattydiesel is starting off with a positive reputation.
located on the right hand fender apron
  #3 (permalink)
Old 11-19-2003, 12:48 PM
Found it! Putting out 13.6. New belt will fix. Thanks!!!!!!
Tags
1997, 2000, 2003, diesel, expedition, f250, f350, ford, locate, located, locating, location, powerstroke, reg, regulator, voltage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
