autolite 2100 2-bbl carb
does anyone know of a good replacement for the stock autolite 2100 2bbl carb? i'm trying to keep it simple and stock. Or would anyone know where i could find a good diagram of the throttle linkage and choke. My recently purchased 67 f100 needs some attention in that area. It appears to be jury rigged.
Websites or pics would help. the chiltons manual is a bit vague.
The throttle linkage is JUNK. I would not waste the time to replace what FORD put on there. Simply run a straight rod from the pedal to the carb. Simple and it works great.
(me like others just have used a coathanger or welding rod to make rod. Just bend a hook on the ends)
A holley will work much better, and for longer, than a replacement Autolite. It will run you $200 at most parts stores(or Summit racing). You can also use an adapter plate and install a 600 Holley 4bbl.
Larry
Larry
does this help ?
if you want it bigger i can send you the file email or ICQ or whatever let me know.
or see it on my website at
http://www.geocities.com/opiefordguy...ageyellow.html
ClatonK
02-11-2019 07:09 PM
coloradotrk
01-20-2015 06:36 PM
crm318
17
05-19-2014 10:40 AM
86ford302help
27
04-04-2013 10:19 PM
2100, 2bbl, adapter, adjustment, autolite, autolite2100, barrel, carb, carbs, carburetor, diagram, ford, install, issue, manual
