Straight piped 2.3
#31
#32
#33
Originally Posted by Redneck-Cowboy
How would a 2.3 Ranger sound w/ a 2 or 2 1/2 straight pipe exiting in front of the back tire w/ a 3 1/2 tip.?
Redneck Cowboy
Redneck Cowboy
#34
To be honest, I could care less as to how it sounds as long as it's loud and annoys people. The engine is shot anyway, so performance isn't a big issue, and it's not like it'll lose that much hp. I have my 300 running straight and I never knew the difference, except the noise. That engine is about shot too, it has over 200K and it's startin to lose comp. That ranger though, it takes so much oil it ain't even funny, but it still seems to have good power.
#35
take off the cat converters also for best sound, if your state doesn't do smog.
i wouldn't worry about losing hp...its a 4 cylinder, and you dont have much to work with anyways. when i driving record clears up and i dont have to worry about getting pulled over, i'm going to do the same.
i dont care about it sounding good, i just want it loud. there are a lot of *** hondas with fart-cannons in my town. i just dont wnat to hear their pieces of sh.t when i'm driving and i'll just rev if they fart their *** imports at me.
#39
Originally Posted by neverenough
Don't straight pipe a 4 cyl, they don't like it. They perform better with a little back pressure. I've run both the glass and turbo, I tend to prefer the turbo. No matter what you do, the 4's just don't sound as cool as an 8.
J&A,j.
#40
i just took it off the cat-back and replaced with with nothing.
sounds the same as oem but 10 times louder. its making me keep my rpms down and i have better low end torque but thats about it.
now i have a true appreciation of what they mean when they say that mufflers absord sound AND VIBRATIONS
straights to the rear would be much better and sound isn't too ricey but its just a four-banger and well, it always will be
#41
#44
#45
Originally Posted by ammo troop
Have a question along the lines of this thread, I bought my 92' Ranger (2.3) and the previous owner had the cat cut off and replaced with a length of exhaust pipe, I have a check engine light on, could it be the lack of cat/backpressure trip a code? or screw up the 02 reading in any way?
Needing backpressure is NOT TRUE. Taking off the muffler WILL NOT cause your engine to go bad. Other problems were the cause, not a free flowing exhaust. Backpressure is a resistance or choking of the exhaust system, ALL cars will be fine with a free flowing exhaust. Burning your valves from "no backpressure" is also an old wives tale. You want exhaust velocity, but you dont want backpressure. They are 2 totally different things.
Take my advise however you want, but any mechanic that tells you that backpressure is needed, is no mechanic I would go to. I wonder what else he is wrong about.
