1996 Explorer Headlight Problem - Ford Truck Enthusiasts Forums
Old 11-18-2003, 01:01 PM
onedangerouswookie onedangerouswookie is offline
onedangerouswookie is starting off with a positive reputation.
Question 1996 Explorer Headlight Problem
I have a problem with my right headlight on my 1996 Eddie Bauer Explorer. The right headlight will not work on dim, but it will work on bright. My left headlight works fine on both dim and bright. I changed the bulb thinking that was the problem but it made no difference. Any help would be gladly appreciated. Thanks!
Old 11-18-2003, 02:53 PM
96explorereddieb's Avatar
96explorereddieb 96explorereddieb is offline
96explorereddieb is starting off with a positive reputation.
It's your lamp out module. Do a search and you'll find a lot of threads about this.
Old 11-18-2003, 06:50 PM
95limited 95limited is offline
95limited is starting off with a positive reputation.
My 95 Limited had the same problem with the left headlight. It was a cold solder joint on the LOM module. I have found one other person who also had a cold solder joint on his LOM. It would be worth a look. The Ford repair CD also has a step by step if it is not your LOM.
Old 11-19-2003, 10:40 AM
Talking 1996 Explorer Headlight Problem
Got it! It was a cold solder joint on the LOM. Thank You very much! Without you help I wouldnt have gotten anywhere with that problem.
Need powerful alternator on F250 Milwaukee1979F150 1987 - 1996 F150 & Larger F-Series Trucks 25 12-12-2015 03:05 PM
One headlight bright, one dim. FarmingFord 1999 to 2016 Super Duty 7 12-10-2014 11:17 PM
1994 F250 headlight dim and dash turn signal indicator light on ? petepetersen 1987 - 1996 F150 & Larger F-Series Trucks 2 05-01-2010 05:47 AM
Ford Nav system display brightness aquaman Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 1 10-28-2009 03:33 AM
dim headlights Rustymuffler Electrical Systems/Wiring 7 01-11-2007 09:49 AM
Tags
1996, 1996explorer, 96, explorer, ford, headlamp, headlight, problem, problems
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
