Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-17-2003, 11:52 AM
Boficus Boficus is offline
Boficus is starting off with a positive reputation.
General Used Diesel Trucks Question
I am considering of buying a used Ford Diesel pickup truck in the future. My budget will probably keep my choices to the pre-Power Stroke engine trucks. From what I have seen in the forums, there's two types of engines that were offered in the trucks of this age, a "Pre Power Stroke 7.4" and another type that's quieter.
I also would like to hear any pitfalls and troubles that these older diesels have had. I already understand starting in cold weather is one common problem. I also understand that the 7.4's are rather noisy as compered to other engines.
Anyone out there care to please comment on their older diesels and how they are faring in terms of reliability, durability and ease of use?
My intended use for the truck is infrequent light towing (3000 lbs max.) and general light inter-city use.
Also, what fuel mileage can one expect from the 7.4 liter motor?
Many thanks
  #2 (permalink)
Old 11-17-2003, 01:11 PM
fordiesel69 fordiesel69 is offline
fordiesel69 is starting off with a positive reputation.
For correction, there are TWO types offered, the 6.9L IDI, and the 7.3L IDI. The 6.9 was offered from 1983 thru 1987 whereas the 7.3 was offered from 1988 thru 1994.5. From 1993.5 thru 1994.5 there was a heavier duty turbo diesel.
Both engines are pretty much identical except for the bore, stroke, and head bolt size.
Some of the pros and cons of the 6.9L:
Pro's
Generally easier to start
Slight chance of cavitation
Almost as powerfull as the 7.3
Genarally a good dependable engine
Cons
Uses alot of oil, very common problem
Valve lifters can fail, and flatten out the cam
Head gaskets need changed at about 100k
Glowplug controllers are worthless, never work right!!!!!!
Some of the pros and cand of the 7.3L:
Pro's
Very good glowplug system
Uses Less oil genarally than the 6.9L
Bigger head bolts to lessen the chance of head gasket problems
Con's
CAVITATION!!!!!!!!!!!!! Can happen between 75k-150k
Harder to start due to the glowplug angle was changed
Chassis to engine harness has a problem with melting. Very simple fix though.
All in all, these are both pretty good engines. If it starts, runs good, and does not smoke whote or blue, then you will be fine. Concern yourself more with the condition of the truck rather than the engine.
__________________
My Rigs:
86' F-250 XLT Lariat,6.9 Diesel, Extended Cab, 4x4, 4.10's, 8'bed, Push Button Glowplugs, etc...
99' Crown Vic Police Interceptor (P71) w/Steet apperance package
  #3 (permalink)
Old 11-19-2003, 12:52 AM
Spectramac's Avatar
Spectramac Spectramac is offline
Spectramac is gaining momentum as a positive member of FTE. Spectramac is gaining momentum as a positive member of FTE.
Or you can get an '87 6.9. They have the 7.3 style glow plug system.
__________________
Malcolm
97 Explorer 5.0 AWD
87 F250 6.9 CTS turbo
  #4 (permalink)
Old 11-19-2003, 08:45 PM
redneckmechnic redneckmechnic is offline
redneckmechnic is starting off with a positive reputation.
Find a truck that has been well cared for and take good care of it yar self. this means regualer routine maintence done on time and with good quailty products. my truck has alwasy been well cared for by the previuos owner and me and shes still kicken.
__________________
85 ford F 250 6.9l 5 speed 4x4 7.5ft snow plow flatbed with dual 4inch stacks 270,000 miles and counting
  #5 (permalink)
Old 11-19-2003, 10:22 PM
Hired Gun's Avatar
Hired Gun Hired Gun is offline
Hired Gun is starting off with a positive reputation.
My 88 7.3 cost near $2,000 in repair a year to keep it running. That was over a 10 year 100,000 miles average.
Pro's:
No power
cool big rig sound.
used lots of oil
smokes
You get to buy $16 a bottle additive at least once a month to make the fuel system live more than a couple months.
You learn to have patience as your not passing anyone ever.
Very heavy front end wears out tires and suspension components rapidly.
You get to spend all your spare time looking for more power and reading articles to help you understand why you like your diesel.
You get to buy more special tools to work on it.
An onboard complete set of tools, jumper cables, spare parts, belts and a tow strap will have you well prepared for every day situations that arise. Don't forget a full can of starting fluid for when you get to the end of your battery power.
Con"s:
Service shops charge more for diesel Parts and labor.
11 mpg highway. 8 mpg with a load.
Fans belts and batteries every other year.
Can't talk while engine is running.
You get to buy a couple new glow plugs every time it gets cold out.
If you ever run it out of fuel it will about cost you a $200 starter and a pair of expensive 1000cca batteries to get it going again.
All the tow companies will send you Christmas cards.
Replacement engines cost three times as much as a gas engine.
The best thing about my 7.3 is it blew the rods out at 188,000 miles and put itself out of me and my neighborhoods misery. That's okay as the remains of my $2,000 fuel system that is only 500 miles old is worth nothing on the resale market. I changed the oil on this every month and it still turned the oil black in the first minute.
__________________
2008 E-350 Super Duty V10 Elec 5-spd AOD Tow/Haul-A$$ mode 4.10LS (Glock 40 in my pocket) No worries
  #6 (permalink)
Old 11-20-2003, 10:18 AM
Sounds like ya had a lemon my truck cost me 500 bucks to buy with a blowen tranny another 500 bucks for the tranny and thats it. alwasy starts never use additive in the fuel never burned up any starters have run out of fuel a couple times and it gets 18 mpg on the high way.
__________________
  #7 (permalink)
Old 11-20-2003, 11:31 PM
MRZ MRZ is offline
MRZ is starting off with a positive reputation.
Hired Gun-
Yikes! Next time you are stuck in that situation, get the vehicle running and trade it on a Toyota Prius or a Segway Transporter.
I long for the days when going the speed limit is okay, and 70 for a truck that was built to go 55 is just fine in my book. Why can't everyone just drive responsibly and slow down? I was hit TWICE in one month, the last one was a trip to the hopsital, and now I am glad when people pass me. At least they are not running stop signs into my passenger door. Seriously, if you hate being passed get a McClaren F-1 or a Porche. If you need to speed well just bite the bullet and be late- just leave early next time º¿º
You had a lemon, roll the dice on another and trade that puppy off. I have never heard of such problems. Heck, that is why I bought a diesel, everyone I knew around me was getting at least 15 mpg and so far I don't regret it one bit. Plus it is big and people don't tend to smack into this one while speeding and passing, talking on the cell, while eating their cheeseburger.
__________________
1965 fairlane
1970 cl450
1972 cb350
1974 cb550
1974 cb750
1979 f150
1983 k-20
1984 c-10 (old ladies)
1990 f350
1997 cbr1100xx
  #8 (permalink)
Old 11-21-2003, 09:16 AM
Hired Gun's Avatar
With my 7,000-pound trailer it wouldn't even do 55 most of the time and as far as passing that would only be possible if they actually pulled off and parked. I have never had a speeding ticket and don't mind being passed. I also have never been in a car wreck, as I know how to drive very defensively. As far as being on time when I travel I usually get there 2 or 3 days early if nothing breaks. I drag race all over the northwest and do my racing on the track, never on the road.
The load in this picture here is near 22,000 pounds combined. I am extremely responsible and have never had a mishap on the street.
I wish I could trade this off but the replacement cost for me is near 100,000 dollars due to all the modifications that need to be done for me to drive it. I did the next best thing and put a nice 460 in it. I lost one mile per gallon and tripled my horsepower so now I’m not hazarding the road with another rig going 26 miles per hour on every grade and no one has to risk their life anymore to get around me when I didn’t have the power to even, get to the speed limit. I now can hold the limit on any grade with any load.
After you have had yours 10 years or so then you come back and tell me how great it was. By then you will have done injectors a time or two, went through a couple dozen glow plugs, belts, and a water pump. You might have even got to spend some quality time somewhere waiting for a tow truck and being at the mercy of some shop that charges to make your truck worse. If you like to tinker, and have something else to drive when it is not working then a diesel is for you as it will nearly always need something done to it. Now if you don’t drive it or work it like I have then maybe it will last forever
__________________
  #9 (permalink)
Old 11-21-2003, 08:06 PM
I dont no ive owned my truck for about 5 years now and it has close to 300,000 on the orginal motor injector pump and yes even the injectors are orginal. I dont no if the glow plugs have been done but ive never done them and they do get used up here in northern new york. I also pull cattle trailers with the truck some sl;ightly over weight and can alwasy hold a decent speed and keep up with tractor trailers on the hills. Ive only ever been in one wreck with my truck and thatw as when a lady yaking on her cell phone blew a stop sign and decided to clean the mud off my plow frame with the side of her van. luckily no one was hurt but she sure did learn one lesson that day. I am sorry that ya have had such bad luck with yar diesel ive never really heard of any body thats had quiet that much trouble on the same engine.
__________________
  #10 (permalink)
Old 11-21-2003, 09:32 PM
kidoo kidoo is offline
kidoo is starting off with a positive reputation.
This is my second ford 7.3 and of course being a F250 it is more expensive to repair than a normal light duty truck. I bought the truck because I have a Truck camper, near to 3000 pounds in the bed. What I like is the fuel millage and in order to get the same power i would need a big gas engine that would be quite expensive on gas. I also like the sound, makes you feel you have a real heavy duty truck.
As for gas engine truck, if it is old, you still have problem to fix. If it is new, the are now very complicated to fix with all the electronic.
Well, may be you are right it is touchy on the injectors and glow plug, but, it is a real truck, not the fancy stuff.
Cheers,
__________________
Black and chrome beauty, F350 Lariat, crew cab diesel, 8 foot box, 2006, 4x4, Fun toys, Kodiak Camper, Zodiac boat, Polaris ATV, Scandic sleed. Life is short, take it all.
  #11 (permalink)
Old 11-22-2003, 01:32 AM
Spectramac's Avatar
Hired Gun,
Sorry you had all those problems with your van. It sounds like you had a few cases of mechanics not really knowing what was wrong with your engine so they just threw parts at it until it started. That's the only way you could've changed all those parts in that span of time. I have noticed these engines don't seem to hold up as well in vans (no reason why). I work on these things at least a couple times a week, 95% in pickups. They all hold up well and usually get to around 300,000 miles before they need to be yanked. Glad you found a solution to your problem, even though you had to jump ship on the diesel.
__________________
Malcolm
97 Explorer 5.0 AWD
  #12 (permalink)
Old 11-23-2003, 11:17 PM
Ford rocks and rules Ford rocks and rules is offline
Ford rocks and rules is starting off with a positive reputation.
Hi All
Just joined up. Great site. Just wanted to add my 2 cents on the topic-my 1991 f250 4x4 has 360,000 km. with no major work. It runs like a champ with tons of power, no smoke and 21 miles per Can. gallon.
  #13 (permalink)
Old 11-25-2003, 03:37 PM
beretzs beretzs is offline
beretzs is starting off with a positive reputation.
I have no idea about your van but my truck is at 125,000 and is still really strong, the PO never did anything to it. I found this out when I put the turbo on and looked over the engine, still all factory equipment. My father ran his 1986 4X4 F250 for 300,000 some miles before he retired it. It still runs, he just needed a new rig, Logging beats up trucks. You are right, they are not powerhouses but the do pretty well. Sounds like you had a whole lemon grove parked in your yard. If you look around where I am from the are still the old fellers driving their F250's 6.9's from the first ones that rolled off the line and they have had very little trouble with them and they have most all been used as farm trucks alot, so with that. Sorry but don't bash the truck because of one bad seed. My father had a 1987 F350 Dump that blew its first 460 at 67000 and that truck got babied so much more than any truck he ever owned. It is not that the 460 was a bad engine its that the engine was made on a Monday or something. Scotty
__________________
Semper Fi, Scotty
1987 Ford F350 4X4, 6.9 Liter Banks sidewinder, 4" straight piped, C6 Tranny, 4.56's, 6 inch skyjacker and 37" Super Swampers
1977 Jeep CJ5, 4" lift, 33's and a built AMC 304 4.10's F-R with a Detroit Locker in the rear and a Powe
  #14 (permalink)
Old 11-29-2003, 01:10 AM
fonefiddy fonefiddy is offline
fonefiddy is gaining momentum as a positive member of FTE.
Quote,
"The load in this picture here is near 22,000 pounds combined. I am extremely responsible and have never had a mishap on the street. "
Um, you need a bigger truck!
No wonder the poor thing gave you problems.
I've read more good stories than horror stories regarding the old IDI's. They were no hot rods, but they are depenable, cheap and easy to maintain.
__________________
93 F One Fiddy- 5.0/AOD/3.55 230K OEM
93 F Two Fiddy Scab- 7.3/ZF5/3.55/Sidewinder II,94 Turbo pump,G Inj's, Velvet Ride, Ride Rite Rear, Turbo Bumper, Alcoa's
85 F Two Fiddy-6.9/C6/3.54/ Holley Red, Racor, Soup Bowl,AutoJet 3",Ride Rite Rear
http://www.ford-trucks.com/user_gall...149391.520.390
  #15 (permalink)
Old 11-30-2003, 01:03 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
22,000 towing is no problem. 17,000 truck alone is no problem either. I do that lots with my 86 F250 with a 9' dump bed. Over 250 k miles and still going strong with original motor. A few glow plugs and a vacuum pump are the only repairs, just very regular oil and fuel filter changes.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
