best rearend gear ratio - Ford Truck Enthusiasts Forums
Old 11-16-2003, 08:03 PM
fordman428's Avatar
fordman428 fordman428 is offline
fordman428 is starting off with a positive reputation.
what is the best rearend gear ratio for my truck that is going to have more than likely a hopped up 390 in it, the guy that had it before me put a low gear rearend in it to pull wagons to town on the farm, the truck is a 1975 f150 has a shot 360 in it right now, i want to race with it is what im getting at, i hate people that think there chebby will smoke me., is a low geared rearend better or a higher one for racing with a hopped up 390 in it.
Old 11-16-2003, 08:28 PM
fordeverpower's Avatar
fordeverpower fordeverpower is offline
fordeverpower is starting off with a positive reputation.
i have been a fan of 3.50 gear ratio or so. Its not to high or to low. If you get 4.10s you will have no top end and 2.75s you have little acceleration. If your 390 makes good power and have small tires you could get away with 3.25s.
Old 11-17-2003, 12:22 AM
proeliator proeliator is offline
proeliator is a splendid one to beholdproeliator is a splendid one to beholdproeliator is a splendid one to beholdproeliator is a splendid one to beholdproeliator is a splendid one to beholdproeliator is a splendid one to beholdproeliator is a splendid one to behold
Why does everybody ask this question but never give their tire size? You've got to tell us your tire size if you want an accurate answer...
Old 11-17-2003, 01:10 AM
clean79150 clean79150 is offline
clean79150 is starting off with a positive reputation.
If you want to race your truck, and you already have a low rear end - then just build that motor.
Old 11-17-2003, 08:09 AM
TorqueKing's Avatar
TorqueKing TorqueKing is offline
TorqueKing is gaining momentum as a positive member of FTE.
very good advice so far, I'd like to add that the best gear ratio depends on how much "race" and how little "street" you are willing to put up with. The size of you tire will effect the rearend ratio as was mentioned, if you have large tires on your truck then you need an even lower (numerically higher) gear. If you have 31" or larger tires, it will be a dog with anything less than a 4.10. Might not be a dog, but it won't accelerate like you'll wish it did. For racing, the lower the gear you can use, the better. For street, the ideal gear for fuel economy with a 3 speed automatic trans is around 3.0, but this number works for 29" tires (255/70/R15). Anything taller would require at least a 3.25 to acheive optimum efficiency.
Keep in mind also that if you want a ratio any larger than a 4.56, you will have to use a "Daytona" type pinion carrier if you have a 9" rear. The super-low (numerically high) gears have so many teeth on the pinion gear that it will not fit in the carrier.
Old 11-17-2003, 05:30 PM
fordman428's Avatar
well i have regualr 15's on it right now and dont plan on getting bigger, the truck also has a lower rearend gear ratio than what came in it stock.
Old 11-18-2003, 09:09 AM
original67 original67 is offline
original67 is starting off with a positive reputation.
I like the 3.73 setup, it is very powerful off the line, and still gives you reasonable top end.
Old 11-18-2003, 09:35 PM
fordman428's Avatar
what did most f150's come with my trucks a 1975 f150 2 wheel drive.
Gear ratio question sharp195 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 04-01-2013 09:43 AM
1952 F-1 Ford Pickup rearend Fordpk52 1948 - 1956 F1, F100 & Larger F-Series Trucks 23 09-26-2012 01:40 AM
Help with rearend tag. restoringmy46 1973 - 1979 F-100 & Larger F-Series Trucks 2 12-03-2011 07:33 PM
Needy RearEnd?????? kevinfelix 1961 - 1966 F-100 & Larger F-Series Trucks 16 08-03-2010 12:59 PM
RATIO OF A 1960 FORD F500 2 SPEED REAREND emailhemphill 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 12-31-2009 07:01 PM
Tags
2003, 300, 400, cylinder, end, engine, f150, f250, ford, gear, gears, ratio, rear, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
