Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southwest Region > Arizona Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Arizona Chapter Join Chapter, Leader: Bill W
  #1 (permalink)
Old 11-16-2003, 06:16 PM
PDK PDK is offline
Garage is empty, add now
PDK is starting off with a positive reputation.
Angry F250 will not start - been in storage
need advice.
2000 F250 will not start - been in stoage for 3 mo. - ran well prior to being parked.
have done the following ...
New Batts
purged fuel filter bowel
Good fuel.
Fuel Pumps works well
starts when using WD40 as a starting precurser but then engine dies.
No smoke - seems just not gettting fuel.
checked fuel shut off.
Checked all fuses.
All wiring okay.
Any other things to check ?
Know any Ford mechanics in Phoenix area I can call on and trust ???
thanks inadvance
Phil
  #2 (permalink)
Old 11-17-2003, 01:19 PM
wabiker wabiker is offline
wabiker is starting off with a positive reputation.
...Plugged exhaust...?
... " catalytic convertor?
I was gonna suggest fuel pump relay.
__________________
79 F250 Ranger
460ci...OEM
94 XLH
1200cc...Not OEM
http://www.ford-trucks.com/user_gall...oid=57646&.jpg
  #3 (permalink)
Old 11-20-2003, 08:46 AM
bronco351 bronco351 is offline
bronco351 is starting off with a positive reputation.
First off.. you might want to try the superduty forum.
I Can help though. Is this truck a Diesel or gas?
Your problem is definelty fuel starvation. That is obvious due to the fact that it starts by spraying a fuel source into the intake.
Since you said this truck sat for 3 months I suppose there is rust in the fuel system.
You should replace the fuel filter. Then drain out ALL of the old gas, this includes running the fuel pump to drain all the fuel lines.
THen I would pull all the Fuel injectors and clean them up with CLR if they have any rust on them.
Also you should pull the spark plugs and check if there is any moisture on them. If there is it is time for new spark plugs.
If your truck is a Diesel let me know. I have more stuff to say.
By the way, what did you do to the truck BEFORE you stored it?
__________________
-1998 Ford P71, THIS CAR IS SCAREY FAST!!!
-2003 F-350 Dually, Crew Cab, Turbo Diesel, 4x4, BLACK!!!
  #4 (permalink)
Old 11-20-2003, 11:27 AM
PDK PDK is offline
Smile
bronco1 - thanks for the reply. problem is resolved . I did in fact post on the SD 7.3 forum as well. lots of good info and replys.
root cause was a rodent problem a chewed fuel sys sensor wiring.
thanks to you all who replied.
PDK
Tags
1999, f250, start, storage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
