TTB oil drain
11-15-2003, 02:42 PM
on
TTB oil drain
After a 'wheelin trip with my buddies to the mud bog in my 1990 f-150 4x4, I found the oil in the front end had some water in it. I noticed it didn't have a diff. cover or a drain plug like the 8.8 in the rear. What's the easiest way to get the oil drained? All replies are appreciated. Thank You
11-15-2003, 03:37 PM
I had to pump mine out. I don't like the design of the front axle. Wish they could have thrown a drain plug in. I really hate to think how much crap didn't get sucked out when I changed the lube oil in the axle.
11-15-2003, 03:39 PM
on
You can loosen the bolts and pry the 3rd member loose, and let the oil drain out, then tighten everything back up and pray it dosent leak; or you can use a suction gun to suck it out. You are actually suppossed to remove the 3rd member, but these are a few tricks I've learned.
