98 F-150 4x4 gas mileage - Ford Truck Enthusiasts Forums
Old 11-15-2003, 02:15 PM
jrell jrell is offline
jrell is starting off with a positive reputation.
I just bought an 98 F150 4x4 4.6L w/ 157,000. Its been on the highway twice both times very windy used almost 3/4 of a tank of gas and I went about 160 miles. Around town it get about 10 mpg. I know I'm not going to get great mpg but is this normal. What can I do to get better mpg.
Old 11-15-2003, 08:52 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
Hi jrell and welcome to the forum
Any idea if your truck has been tuned up recently? That can make quite a difference.
Until you figure out the actual mpg a few times though you dont really have any numbers to compare to what other people are getting. There are lots of posts about gas mileage here if you search for them.
Old 11-15-2003, 11:36 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
This is low, I was getting 11mpg with a bad vacuum hose and a bad MAF causing it to run ful rich. Got it repaired and back to 14mpg.
Jimmy
Old 11-16-2003, 04:39 PM
aldridgec's Avatar
aldridgec aldridgec is offline
aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.
I recently had concerns about MPG, and pulled the two easiest plugs to check condition. The very front plug hole had gotten some moisture in it and built up some rust. So I blew out the hole, and cleaned the coil boot very well on both plugs. This last tank i went from 11.5 to 12.5 mpg. I'm hoping to get near 14. I had just recently taken a long trip (about 4 hrs of driving each way) and couldn't get near 300miles to the tank which really concerned me because it was all highway, eliminating the possiblitiy of my lead foot. So I am going to do all the plugs despite the 100k mile rec interval, I think it will make a difference.
Chris
***MPG HELP**** Willie928 1987 - 1996 F150 & Larger F-Series Trucks 17 10-05-2012 11:06 PM
mpg difference 06 F150 2 wheel drive vs 06 F250 4 wheel drive doubleg Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 8 05-26-2011 12:33 PM
ranger mpg HotrodSmurf Ranger & B-Series 17 01-16-2011 11:07 AM
gas mileage 2y4x 1987 - 1996 F150 & Larger F-Series Trucks 11 04-29-2005 06:24 PM
98 F-150 4x4 lousy mileage help?!?! TKONO 1997 - 2003 F150 11 02-19-2002 10:40 AM
Tags
150, 250, 4x4, 98, bad, f150, ford, gas, losing, low, milage, mileage, mpg, v8, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
