Thermostat and performance
Looking for some opinions here...
If a tstat is stuck open, what are some of the symptoms of performance? I know it throws things out of wack. Im driving a 95 F250 351w (my uncles truck). Its getting cold and snowy...the defroster aint that great(luke warm) and the performance is kinda like s***. Fresh tune-up few months ago. The idle is kinda poor in park and sometimes in gear. Once in awhile if Im stoped and hit the gas to go, it seems to bog down then suddenly take off full force...this isnt all the time though. Im thinking the tstat because of the defrost issue and the info the computer is getting thinking its always running cold. Also, my temp gauge doesnt rise and come back down as the stat would open. It only rises to just before the "n" on "normal" to me it seems to low. On my 89 it stays around the "r". All advice welcome...its a blizzard out there......later
Well hope this helps. Fords don't seem to run worth a darn when cold. All of my trucks (4) run like doo-doo till warm, then they run like a raped ape. My 84 w/ 302 is almost a nightmare till warm, won't idle runs horribly rough etc. If the t stat is stuck then it never really gets up to the right temp. Like I said hope this helps. OOOOOOOOOH yeah with a new stat your defrost will be like an oven, all Fords have awesome heat. Like I said hope this helps.
CJ
CJ
