help
help
got a problem, any advice will be appreciated. About 3 months ago my truck had a serious habbit of cutting off while I was driving. The local ford shop ran test on everything and said nothing was wrong and I got it back and it ran fine until now. I had to replace my battery today and as soon as i changed it the alarm on my truck would not go off so i disabled it and took it to my stereo shop.............they found out that i have some kind of electrical prob...............Everywhere under the hood I have 12 volts but under the dash at the ignition I only have 9, but it jumps up and down from 9-12 diff everytime they check it.
help if u can...........
Although I tend to lean towards agreeing with Joe about the Voltage regulator, which you should still check, you may want to also check the ground wire to your alarm, as these can sometimes cause problems such as yours.
Let us know what you find.
I'm pretty sure it's the alarm ground wire though.
tom
tom
Strick,
You know me, normally I tend to agree with Joe on repair issues.
However, this time I feel I have to disagree.
I really pretty certain that it's your ground wire to the alarm, and not the alarm ground wire, as Joe suggests.
Also, he is suggesting that your voltage regulator may be jumping and causing a problem with the ground wire.
Well, in my experience, Voltage regulators don't jump...per say, but rather frolic or skip in a jolly type fashion. Although all of this frolicking could tend to be annoying, I don't feel that it's affecting your ground wire. I think that, if anything, your ground wire would simply slap the voltage regular and tell it to "Knock it off".
Tom
Tom
Originally posted by Busa01
Strick,
Tom
Strick,
Tom
LoL LoL!! Oh my God, I can't beat that one! You are the master Tom. I couldn't stop laughing man. You win!
