93' F-250 4x4, Sagging front end - Ford Truck Enthusiasts Forums
Old 06-14-1999, 11:32 AM
Matt Hochstetler
Guest
Posts: n/a
I was told the sagging front end of the 4 wheel drive 3/4 pickup was a factory defect. The shocks bottom out and/or the bump stop hit the leafs when driving over something at low speed (not noticed while driving 20 mph). I was wondering if there were any options I had to replace the front end suspension to prevent the bottoming out and possibly level out the front end?
Old 06-14-1999, 03:32 PM
Phillip Guidry Phillip Guidry is offline
Phillip Guidry is starting off with a positive reputation.
The brand Superlift makes a spring helper kit that will boost your front end back up.The diesel kit is the one I bought for maximum lift.
Phillip
Old 06-14-1999, 06:50 PM
H8monday H8monday is offline
H8monday is starting off with a positive reputation.
Fords are kinda notoriouse for drooping or sagging front ends.I also went to Superlift when I lifted my truck,but they do make agreat spring kit just to bring it up in the front but to maintain a higher but stock look.The truck looks so much better when its not sagging,(they just look like they are kinda "road hard and put up wet" when they are sagging. As Phillip pointed out the Diesel springs are the only way to go,especialy if you are running the diesel or big block.If you are looking into raising your truck for off road let me know and Ill give you a few do's and dont's.
Later,
Jeff / super@sierratel.com
91 F250 4x4
Old 06-20-1999, 12:15 AM
Pouder Pouder is offline
Pouder is starting off with a positive reputation.
Am intrested in your does and dont's in lifting my sons 92. Am looking at Tough County 4 inch. the truck does sag bad, deisel motor. Thanks.
Old 06-20-1999, 12:53 PM
car 36
Guest
Posts: n/a
Old 03-31-2010, 05:31 PM
Off Duty Off Duty is offline
Off Duty is starting off with a positive reputation.
I had a similar problem with my truck. Now depending on what you do for work or have access to I used one International truck spring on each side it leveled it and handles great
Old 04-01-2010, 06:40 AM
Towmanjbo's Avatar
Towmanjbo Towmanjbo is offline
Towmanjbo is a name known to allTowmanjbo is a name known to allTowmanjbo is a name known to allTowmanjbo is a name known to allTowmanjbo is a name known to allTowmanjbo is a name known to all
These trucks were not level new. The rake is supposed to be there so that when a load is put into the bed the truck sits level.
Old 04-01-2010, 10:33 AM
darthice's Avatar
darthice darthice is offline
darthice is starting off with a positive reputation.
i have a problem when i park my truck after backing it up it sags more than usual and looks like my alignment is out of whack. i think my springs are in need of being changed i know they havent been changed since i got the truck
Old 04-01-2010, 10:38 AM
BlueOvalBoy19 BlueOvalBoy19 is offline
BlueOvalBoy19 is starting off with a positive reputation.
Leveling kit unless ur looking for a lift kit.
Old 04-01-2010, 10:45 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Quote:
That's normal behavior for all TTB Ford trucks, the wheels will straighten themselves out as soon as you pull forward again but if a little sag /-\ remains that indicates the springs are sacked and need to be replaced.
Old 04-01-2010, 10:55 AM
darthice's Avatar
Yeah thats what i figured the springs are like 18 years old i would imagine they need to be replaced.
Old 04-01-2010, 11:44 AM
andym's Avatar
andym andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
Someone's been thread mining.
This one's only 10 years old.
Old 04-01-2010, 11:47 AM
darthice's Avatar
yeah i just noticed that now that is bringing a thread back from the dead but at least someone is using the search feature of the board
Old 04-01-2010, 11:50 AM
1994F2507.3L's Avatar
1994F2507.3L 1994F2507.3L is offline
1994F2507.3L is gaining momentum as a positive member of FTE.1994F2507.3L is gaining momentum as a positive member of FTE.
Quote:
what springs are you talking about? the leaf springs? thats the only "springs" up there i guess right
Old 04-01-2010, 11:52 AM
darthice's Avatar
on 2wd f150s they have coil springs in the front
Front suspension sag bobbyreb97 1997 - 2003 F150 3 01-09-2015 04:07 PM
Front end sag? hhowell1990 1999 - 2003 7.3L Power Stroke Diesel 18 11-30-2014 11:24 AM
Identical 2013 F250's 1 3/4" Different Rear Sag LaxPlaya21 6.7L Power Stroke Diesel 12 11-29-2013 01:53 PM
what can cause front end sag powerstroker100 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 22 08-03-2010 08:09 PM
'96 PSD front end sag solutions fireman-175 1987 - 1996 F150 & Larger F-Series Trucks 1 03-17-2007 07:12 PM
Tags
1996, 250, 4x4, 93, diesel, donts, dos, f250, ford, front, raisning, sagging, springs, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
