Aerostar Ford Aerostar
Noise in left front suspension
Old 12-07-2003, 11:07 AM
biederboat's Avatar
biederboat
biederboat is offline
Question Noise in left front suspension
The wife's 93 AWD Aerostar is making a "thunk" in the left front when you stop & go from fwd to rev or vice versa. I think it's also causing a slight vibration. I suspected hub or halfshaft. I jacked up the front, the only thing I detect is play from left to right, none up & down. It doesn't appear to be the tie rod. Both wheel seem to go fwd & rev about the same, no grinding or excessive looseness. The half-shaft appears to be turning okay, no cracks in the boot or anything. Upper control arm bushings look fine.
Anyone have a guess?
Thanks,
Biederboat
biederboat
1978 - 1996 Big Bronco
08-10-2005 09:02 AM
TimLynch
Aerostar
13
06-29-2005 07:58 AM
TCollier
05-29-2004 03:01 PM
biederboat
Aerostar
10-13-2003 12:44 PM
biederboat
Aerostar
04-21-2002 08:24 AM
Quick Reply: Noise in left front suspension
