1984 F150 4.6L Starting Problem
Old 11-26-2003, 09:45 AM
skidrowe's Avatar
skidrowe
skidrowe is offline
I recently bought this truck and replaced the plugs and wires. When I went to start it, I had to lift the coil wire out of the distributor cap before it would run. Since then I have replaced the distributor w/ modulator, rotor and cap and the ignition coil all with the same results. The engine will start and run with the coil wire slightly pulled out of the cap, but dies when I press it onto the cap. I'm at wits end trying to figure this problem out and would appreciate any and all suggestions.
Old 11-26-2003, 11:19 AM
LxMan1's Avatar
LxMan1
LxMan1 is offline
How did you get the 4.6L in an 84?
The 4.6L never has a distributor.
Could it be a 4.9L 6cyl. perhaps?
I am wondering if the pick-up coil in the distributor is going bad?
Jimmy
Ghosttowner
18
12-23-2014 09:37 PM
treedoctor
08-23-2013 08:07 PM
amphiduck
10-28-2012 11:54 PM
Norm Spaulding
15
03-10-2008 07:23 PM
53redford
12-13-2007 04:51 PM
Quick Reply: 1984 F150 4.6L Starting Problem
