Gasket preferences?
Gasket preferences?
Looks like it's time for me to replace the lower intake manifold gaskets, darn it. So far one local shop has offered a Fel-Pro head set for around $45.00. Another shop has a Victor head set for the same price. I haven't checked with $$Ford$$ yet. Anyone have any comments on Fel Pro vs Victor gaskets, or any other good brands?
Thanks
Thanks
Well, I went with ford intake and cylinder head gaskets.....about the same price as the ones used in the $8,000 engine.
JUst make sure that when you install the new gaskets, lay a thin bead around each water passage on both sides in order to avoid coolant leaks.
ALSo lay a thin bead along the inside of the lifter valley where the cyl head meets the block (under each corner of where the intake meets the head) and smear it smooth to seal the lifter valley.
When I called Ford a month or so ago and priced the lower intake set, they wanted something like $75. I asked again, same price. Picked up the Felpro blues from AZone for about $10.
After a month of driving a borrowed Jeep (yuck), I think I'm finally going to finish putting the Bronco back together.
MONAVIERONJON
08-29-2012 07:39 AM
steveterryrudy
1997-2006 Expedition & Navigator
03-10-2012 09:01 PM
pclayton
01-05-2012 05:27 PM
JoeVR5
1983 - 2012 Ranger & B-Series
08-09-2011 09:07 AM
Todd
07-10-1999 11:23 AM
