9 vs. 8.8???????
Are the u-joints the same size? If so, you can press the flange off and bolt them onto the 9" with it's u-bolts. I'm not familiar with the stock 9" I'm used to seeing them under race cars. My '87 has the 8.8" and has u-bolts, not the flange like you have, so they may be the same size, I don't know for sure.
I didn't crawl under and measure and all, But I was looking at my dad's 82 That had a whole 94 Frame and drive line swapped into it and my 86. My 96 has the 9" and his now has the 8.8. It looks like the 2 has the same joints. Since the Flange is held onto the shaft with u-joints you can probably remove that shaft Flange and Place it onto your drive shaft then just bolt it up like the 8.8. Just check your shaft travel after to be sure it has enough room to travel when flexed. If I don't come across the right 9" before to long I'll be doin a temp. 8.8 swap on my 79 Bronco it'll I find, save enough $$ to built a 9" or run across a 1 ton parts truck to rob the drive train from. Plus I'm kinda wondering how well the 8.8 fairs when 35" TSL boggers go to bitting.
Welder Guy
1997 - 2003 F150
05-29-2012 08:23 PM
