block bolt pattern question - Ford Truck Enthusiasts Forums
Old 11-11-2003, 06:41 PM
stargazer stargazer is offline
stargazer is starting off with a positive reputation.
Question block bolt pattern question
okay a buddy asked me the other day if the flathead had the same block to clutch housing bolt pattern as the Y and FE. I told him I wasnt old enough #1 to know this and I have never seen a flathead close enough to know. I said I would ask. is it the same?
Old 11-12-2003, 12:16 AM
mtflat mtflat is online now
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
I don't have a Y block or FE to compare, but I've been told the flathead is unique and won't match the others.
Old 11-19-2003, 08:53 AM
Paso1 Paso1 is offline
Paso1 is starting off with a positive reputation.
I'm pulling the 239 flathead out of the 54 and installing a 292 from a 61 I've been told it's a straight bolt in, I'll find out next spring for sure. Apparently the US made 54's had some OHV Y blocks installed but the Canadian built still used the 239 flatheads model Q & model QHS show in the 53 parts manual as having the Y block.
Old 11-20-2003, 06:28 AM
ke6bnl ke6bnl is offline
ke6bnl is starting off with a positive reputation.
I have a 239 flatthead and a 3speed on the floor, what newer motors are a bolt in thanks as a kid I had the same truck it had what I was told a 57 ford motor 289??? if the motor is shot I may go with a newer style ohv motor. thanks Ed ke6bnl
Old 02-07-2004, 07:16 PM
312 312 is offline
312 is starting off with a positive reputation.
the 292 will fit if you have the complete motor including bellhousing.all 54 fords in the u.s. were overhead.all in canada up to at least 3 ton were flathead.i was told this happened because ford in the u.s.had a mountain of flatheads left over and basicly dumped them on ford of canada.
Old 02-07-2004, 08:09 PM
Steve_B's Avatar
Steve_B Steve_B is offline
Steve_B is gaining momentum as a positive member of FTE.
I have a South African Built 54 F100 which has the original Flathead, also right hand drive
I believe Australian and New Zealand trucks are the same
Old 02-08-2004, 09:46 AM
312 312 is offline
steve,as far as i know all australian and new zealand fords wereimported from canada.i would be willing to bet that the same was true for south africa.
Bellhousing Bolt Patterns 460/5 1973 - 1979 F-100 & Larger F-Series Trucks 23 11-18-2009 05:49 PM
1951 f-8 winch truck needs restored 89ford73 1948 - 1956 F1, F100 & Larger F-Series Trucks 27 10-29-2008 11:01 PM
FE bellhousing vs. MEL bellhousing pcmenten FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 20 08-08-2007 07:08 PM
flathead swapping/upgrades loosecannon39 Flathead V8 & Flathead 6 3 04-22-2006 02:38 AM
Fordomatic/FE campatibility krautwolf Clutch, Transmission, Differential, Axle & Transfer Case 0 05-20-2005 07:31 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
