460 EFI vapor lock? - Ford Truck Enthusiasts Forums
460 EFI vapor lock?
Old 08-21-1999, 08:53 AM
Kevin Kevin is offline
Kevin is starting off with a positive reputation.
460 EFI vapor lock?
Old 08-25-1999, 07:43 AM
Tim Welden
Guest
Posts: n/a
460 EFI vapor lock?
I have a 1992 RV based on a ford E350 chassis with an EFI 460. Whenever I have a long upgrade(which is pretty darn unavoidable here in Colorado :^) the RV appears to vapor lock. It progressively looses power and sputters until it dies completely. This often happens immediately after the uphill when coasting down the other side. If I let it cool off completely it then starts up and runs like nothing has happened! The temp gauge never goes near the "red" on the uphill. This problem seems to be getting progressively more frequent although that might be just the summer temps.
The RV's engine and chassis is bone stock and only has about 45K mi. on it.
My best guess is the in-tank fuel pump but I'd just as soon not try shotgunning the problem. I know I have heard of others with similar problems but I've never heard the solution! Any experience or suggestions would be GREATLY appreciated.
Old 08-25-1999, 07:52 AM
mandm mandm is offline
mandm is starting off with a positive reputation.
460 EFI vapor lock?
I had a VERY similar situation with a 1989 Full size Bronco. Mine was totally temperature related. Let it cool w/ the hood open and it'd start right up. It was under warrantee, and was towed to the dealer. They replaced the fuel filter (!) and that fixed it!!! (I felt a little bit stupid as I could have taken care of it). Try that.. it's an easy job.
Another thing you may want to do is get a fuel pressure test gauge that connects to the EFI rail's Schrader valve. Soon as it dies, hook it up and turn the key on... see if you've got the correct fuel pressure. Your fuel pres. regulator or pump relay may be trying to die. Also, I wonder if the 'in tank' pump's pick up screen could be getting fouled with some junk in the tank, or possibly the pump's pick-up is loose.
One other thing... check the NHTSB's Technical Service Bulletin list... there may be a TSB out on your chassis. (www.nhtsa.dot.gov)
Old 08-25-1999, 03:42 PM
ray ray is offline
ray is starting off with a positive reputation.
460 EFI vapor lock?
Go to rvamerica.com. This problem has been discussed many time. The fuel pump may very well be the problem but the current thought on the mentioned bb is that heat build up is the problem. One of the long time members of that bb has insulated his tank, lines, and installed a cooler in the return line. Has not had a real test of his modifications yet. As someone mentioned, change the filter first. Good luck,
ray
wheels 1973 - 1979 F-100 & Larger F-Series Trucks 7 04-13-2004 12:08 AM
is this common 1987 - 1996 F150 & Larger F-Series Trucks 3 11-12-2002 01:38 AM
Wheelbase 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-14-2002 09:06 AM
Overheating 1973 - 1979 F-100 & Larger F-Series Trucks 8 03-11-2001 10:13 PM
Tags
1987, 460, e350, efi, ford, fuel, injection, list, lock, locks, problem, rv, rvs, tsb, vapor, vapour
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
