Center console on 1993 F150 w/bench seat - Ford Truck Enthusiasts Forums
Old 10-17-1999, 08:46 PM
roderick roderick is offline
roderick is starting off with a positive reputation.
Old 10-18-1999, 09:13 PM
rivermen123 rivermen123 is offline
rivermen123 is starting off with a positive reputation.
I am trying to find out what is available regarding a center armrest/console for a 1993 F150 Extended Cab with a bench seat. I would like to find something similar to the size of what Dodge is putting in their full-size trucks. All the aftermarket stuff is just too small.
Will I have to go to the dealer? Would they have anything that would bolt right in? It doesn't have to flip up, I just want to have a large center console. Thanks in advance for your help.
Old 10-19-1999, 07:09 AM
slik slik is offline
slik is starting off with a positive reputation.
You could look in the junkyards. Ford has had that type of option for a number of years. Also, check out Wrenchead.com, I believe they carry a bunch of seats and Steel Horse and Qualitex make several bolt in aftermarket seats.
Good luck,
Slik
Old 10-19-1999, 10:00 AM
OOPS! It wasn't wrenchead.com; check out <a href="http://www.ultimateparts.com">http://www.ultimateparts.com</a>
They have some seat options.
Slik
Old 10-19-1999, 11:59 AM
H8monday H8monday is offline
H8monday is starting off with a positive reputation.
I went through the same thing when I began modifying the interior of my 91 F250 super cab 4x4.I neede something to house the CD changer,11 meter radio & linear amp,power ports,etc. I ended up building a console that runs from the rear of the seats(leaving enough room to still fold down the rear seat)all the way past the front of the seats and up to the uder side and front of the dash(basicaly covering uo the ash tray section).Then I relocated the cigarete lighter to 3 individualy fused lighted power ports.I was able to install everything I listed above plus still have plenty of room in the lift up portion of the center.I raised it up higer than the stock console(I made it as high as the armrest on the doors).I then lifted the rear seat with an aftermarket kit to make room the stereo amplifiers. The console was not hard or expensive to build,I used 1/2 clear pine wood screws and epoxy wood glue and just placed it in position with every new modification and drove with it for a while to see how everything fit,when I was finally happy with the design,I sanded and added contours to it to make it fit and look factory designed, I then covered it with fiberglass and resin to make it super strong, then took it to an auto upholsterer and had it covered in a cloth that almost perfectly matches the dash material,the upholstery cost me $125 and he did a great job. Most important it has every thing I need built into it,power for cell phone,computer & GPS, the interior lights up when opened,and my CDs have there own little cubbie hole.It was a fun project and I get lots of compliments(and requests to build them).
Jeff
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 04:27 PM
Can someone explain this to me? 1987 - 1996 F150 & Larger F-Series Trucks 11 03-09-2016 01:40 PM
ooops Aerostar 5 01-14-2015 04:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 07:14 AM
DPSE Roachfood 1987 - 1996 F150 & Larger F-Series Trucks 3 03-11-2002 11:21 PM
Tags
1993, 93, armrest, automotive, bench, build, center, console, f150, fit, flareside, ford, horse, seat, seats, steel, wood
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
