offenhouser
offenhouser
anyone heard anything on this intake. I bought a 68 mustang and it has a 302 with stock heads and and offenhouser 360 degree intake. i have not found much info on this intake and was wondering if anyone has any info on it.
i think it is aluminmum and it is a 4 barrel.
is it good/bad??
thanks for any input
is it good/bad??
I guess this is the intake your talking about it states offenhauser 360 high rise equa-flow. It states improved fuel passages, says 180* operate half the time 360* operate all the time the 180* operates half the time due to the fact that one side of the intake is "down" while fuel is delivered to the other side this is eliminated by the 360* design of the offenhauser. The design eliminated flat spots in all rpm ranges. Claims 20hp increase at 6500rpm over comparable manifolds. This is what is listed in the paw catalog, later
http://www.pawinc.com/
that link has nothing more than directions to order the catalog. You can call 818-678-3000 it will cost ya $8 or so. I will mention the prices are so so they have many rebuilt kits including blocks and the book is literally 2 1/8"+/- thick full of every aftermarket piece you could think of and then some. Good luck
