1995 F150 4x4 Front Hub Assembly Breaking
Old 12-12-1999, 09:20 AM
Bill's Avatar
Bill
Bill is offline
When trying to pull my boat out of the back of my property, the ground was wet, so I needed to usee 4 wheel drive. As I was trying to pull, the right front hub made a clicking noise and I lost four wheel drive. Took the truck to the Ford dealer and got the hub fixed. I took the truck back down to pull the boat out out, tires lost traction, then the left front hub broke! 4x4 is push button automatic. I had been using 4 low. Why do these hub assemblies keep breaking. This is not my first 4x4 (my first Ford though). I have never seen a truck break this easy before. Are the front hubs that delicate, I was not rough with it. I would appreciate any info you all might be able to give me.
Old 12-12-1999, 12:45 PM
PAUL_2's Avatar
PAUL_2
PAUL_2 is offline
Bill,
Using 4 wheel low produces lots of torque . Its designed to haul the truck up steep inclines , places that require slow & steady movement . 4 wheel high should be adequate in most situations . I have a 90 F150 4x4 with stock hubs and have never had any trouble w them . Im sure Warn or other makers of hubs make a stronger version .I know they arent the most popular , but I still prefer manual locking hubs .
Old 12-12-1999, 01:11 PM
Bill's Avatar
Bill
Bill is offline
Paul,
Thanks for responding. I used the 4 low because of the slick conditions and pulling up a slight incline. I only needed to pull the boat about 150'. I don't use the 4 wheel drive much, just snow, truck is too nice looking to take off road. I got the muddin out of my system a long time ago. It just suprised me that the hubs broke so easy. Thanks again.
Bill
Old 12-12-1999, 09:52 PM
rick's Avatar
rick
rick is offline
Bill,
those 3 bolt automatic hubs used on the pushbutton system are not very good. I have a 95 F150 4X4 and I replaced BOTH auto hubs before 60K miles. If you really want dependable 4x4, get a set of WARN manual hubs for about $100.
You can get these through your local NAPA store under NAPA p/n 745-3111 which is WARN number 9790.
That will be the last set you will ever buy for the truck.
You will need to change the spindle locknuts to the manual variety when you convert.
Old 12-13-1999, 05:16 PM
si02x's Avatar
si02x
si02x is offline
mx21
09-25-2014 08:01 PM
rcguy79
2004 - 2008 F150
01-10-2014 06:00 PM
Jughead
10-18-2010 03:16 PM
skoveng
1999 to 2016 Super Duty
03-23-2009 09:25 AM
fairlaniac
12-28-2000 11:42 PM
Quick Reply: 1995 F150 4x4 Front Hub Assembly Breaking
