1995 F150 4x4 Front Hub Assembly Breaking - Ford Truck Enthusiasts Forums
Old 12-12-1999, 10:20 AM
Bill Bill is offline
Bill is starting off with a positive reputation.
When trying to pull my boat out of the back of my property, the ground was wet, so I needed to usee 4 wheel drive. As I was trying to pull, the right front hub made a clicking noise and I lost four wheel drive. Took the truck to the Ford dealer and got the hub fixed. I took the truck back down to pull the boat out out, tires lost traction, then the left front hub broke! 4x4 is push button automatic. I had been using 4 low. Why do these hub assemblies keep breaking. This is not my first 4x4 (my first Ford though). I have never seen a truck break this easy before. Are the front hubs that delicate, I was not rough with it. I would appreciate any info you all might be able to give me.
Old 12-12-1999, 01:45 PM
PAUL_2 PAUL_2 is offline
PAUL_2 is starting off with a positive reputation.
Bill,
Using 4 wheel low produces lots of torque . Its designed to haul the truck up steep inclines , places that require slow & steady movement . 4 wheel high should be adequate in most situations . I have a 90 F150 4x4 with stock hubs and have never had any trouble w them . Im sure Warn or other makers of hubs make a stronger version .I know they arent the most popular , but I still prefer manual locking hubs .
Old 12-12-1999, 02:11 PM
Paul,
Thanks for responding. I used the 4 low because of the slick conditions and pulling up a slight incline. I only needed to pull the boat about 150'. I don't use the 4 wheel drive much, just snow, truck is too nice looking to take off road. I got the muddin out of my system a long time ago. It just suprised me that the hubs broke so easy. Thanks again.
Bill
Old 12-12-1999, 10:52 PM
rick's Avatar
rick rick is offline
rick is starting off with a positive reputation.
Bill,
those 3 bolt automatic hubs used on the pushbutton system are not very good. I have a 95 F150 4X4 and I replaced BOTH auto hubs before 60K miles. If you really want dependable 4x4, get a set of WARN manual hubs for about $100.
You can get these through your local NAPA store under NAPA p/n 745-3111 which is WARN number 9790.
That will be the last set you will ever buy for the truck.
You will need to change the spindle locknuts to the manual variety when you convert.
Old 12-13-1999, 06:16 PM
si02x si02x is offline
si02x is starting off with a positive reputation.
Broken Hub or Transfer Case? mx21 1973 - 1979 F-100 & Larger F-Series Trucks 6 09-25-2014 09:01 PM
Front Wheel Hub Assembly...Help Please rcguy79 2004 - 2008 F150 6 01-10-2014 07:00 PM
4WD dash switch Jughead Excursion - King of SUVs 2 10-18-2010 04:16 PM
Front End Vibration - The Locking Hub skoveng 1999 to 2016 Super Duty 6 03-23-2009 10:25 AM
4x4 Problem, Hubs??? 95 F150 fairlaniac 1987 - 1996 F150 & Larger F-Series Trucks 14 12-29-2000 12:42 AM
Tags
150, 1995, 1995f150, 3111, 4x4, 745, 7453111, 95, assembly, f150, front, hub, napa, part, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
