jcb67 try a good brand clay bar & wash entire car with a mixture
of a good soap that is ph balancing with just a little more soap in water than you uasally do. If that does not work use a new sharpie fine point marker this will dye the wax also. Now if all else fails just use that wax witha dye in it allready in it.
goodluck turbo ted
