87 F 250 4X4 Netural Saftey Switch??
I had an 88 F-250 3/4 ton. I had problems with the neutral safety switch a couple of times while I owned the truck. It would act like it wasn't starting and wouldn't start and I would replace the neutral safety switch and it would fire over perfect. I would say this is your problem. I would replace it before I did my ignition switch or anything else concerned with the ignition. It is located under the driver side next to the transmission. Just in case you didn't know.
Originally posted by Fd2504Wheel
Is there anyway to by pass it ?
Try and crank it in any gear BUT park and Neutral. If it cranks in R, D,2,1 or any gear other than park and neutral THEN replace the switch.
The problem you have is a WORN IGNITION SWITCH! It's attached to the key tumbler by a rod, and sits on the top of the steering column. Replace it and your problem should go away.
Voodoo ChildVood
03-16-2010 06:46 AM
