95 f150 clutch
95 f150 clutch
when i put truck into second gear clutch pedal goes to floor and have to lift pedal with foot to get into third. does not do this all the time, only once in awhile. not good with clutches, what is the problem? easy to fix? expensive to have someone else do? this is the only gear it does it in. no squeaking or other sounds can be heard.
