Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 11-08-2003, 07:11 PM
Rockies Rockies is offline
Garage is empty, add now
Rockies is starting off with a positive reputation.
jerking truck and propane pre-heating?
Hi, there,
My 90' F250 diesel 7.3L got some kind of fuel problem. No matter cold or hot, it runs ok for 1 minute when first started, then start idle rough, can't even hold onto 500rpm. Dies half of the time. When in gear, it jerks and stutters all the time and won't go fast no matter how much I press down the gas peddle, it jump forward sometimes without warning. People watching may think I don't know how to use a stick shif.
It's really puzzling to me, I just move to a new place and is it possible the fuel is bad? I just changed the fuel filter and still the fuel filter light sometime go on then off after a while.
Also, since plug in is not an option for me, can I use a propane heater (without flame, 3,000 BTU) or propane camping stove to heat the block? for how long? I live in Calgary, it goes to -20c sometimes.
__________________
  #2 (permalink)
Old 11-08-2003, 09:37 PM
Spectramac's Avatar
Spectramac Spectramac is offline
Spectramac is gaining momentum as a positive member of FTE.Spectramac is gaining momentum as a positive member of FTE.
Sounds like you are sucking air somewhere in the suction side of the fuel lines (from the supply pump back to the tanks).
Another thought, how many miles on that injection pump?
__________________
Malcolm
97 Explorer 5.0 AWD
87 F250 6.9 CTS turbo
  #3 (permalink)
Old 11-08-2003, 11:19 PM
Thanks for the reply. Do you mean the fuel supply line has air leak?
I bought the truck a couple months ago. The previous owner told me he just have the injector rebuilt. So it couldn't be the injector, right?
__________________
  #4 (permalink)
Old 11-09-2003, 03:26 PM
kidoo kidoo is offline
kidoo is starting off with a positive reputation.
I have heard about heating the oil pan using a roll of toilet paper soaked in fuel in a tobaco can. Lignt it up under the pan, protect from the wind and wait. I would do a trial somewhere away from the truck to make sure the flame is not too high but apparently it works.
When I am out in the bush, I plug mine with a gaz powered generator for an hour or two. It works.
__________________
F350 Lariat, 6.0, crew cab diesel, 8 foot box, 2006, SRW, 4x4, 2" front puck, scan gauge II, Rotella ELC, Coolant filter, Adjustable Ranchos, Rear adjustable Air lift, Rear sway bar, on order blue spring, stc.
Tags
jerking, preheated, propane
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
