1988 f150 clutch push rod - Ford Truck Enthusiasts Forums
Old 01-03-2000, 09:17 PM
tony_1 tony_1 is offline
tony_1 is starting off with a positive reputation.
my 1988 f150 300 6 cyl clutch master cyl push rod plastic bushing is worn. how do i pull the pin??
looks weird. thanks
Old 01-04-2000, 11:21 AM
deleontow deleontow is offline
deleontow is starting off with a positive reputation.
Just pull the pin, you may have to turn it and just pull it out, once out, pull the clutch rod off to on side and replace the bushing, though check the area were the bushing goes, as when it wears out, it tends to wear the linkage where the rod goes and you have to replace this if this is the case. All available through ford
Dave
<a href="http://members.aol.com/deleontow/auto/index.htm">http://members.aol.com/deleontow/auto/index.htm</a>
Old 01-27-2000, 02:37 AM
SPLabar SPLabar is offline
SPLabar is starting off with a positive reputation.
Beware of the pushrod breaking. In my experience once the bushing wears out the pushrod eye usually breaks soon after. I have broken 3 or 4 over 100,000 miles. I have replaced the arm that goes on the clutch shaft to no avail.I finaly made one out of steel a few months ago. This one won't break.
Old 01-27-2000, 02:44 AM
Push rod came out of brand new master! Dstosh 1999 to 2016 Super Duty 1 10-01-2016 11:08 PM
Sourcing Clutch Master Cylinder kellen302 1987 - 1996 F150 & Larger F-Series Trucks 3 01-29-2016 03:11 PM
95 F150 Clutch Lever Removal jon.smith 1987 - 1996 F150 & Larger F-Series Trucks 1 01-30-2014 05:30 AM
Fasteners cadriver Ranger & B-Series 8 05-04-2007 05:05 PM
code 45 plus slow clutch pedal return 83red150 1987 - 1996 F150 & Larger F-Series Trucks 10 12-22-2006 03:32 PM
Tags
1987, 1988, broke, bronco, bushing, clutch, cylinder, f150, ford, ii, master, push, pushrod, removal, replace, rod, rods
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
