Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 11-07-2003, 10:29 PM
tx_ranger is starting off with a positive reputation.
'01 Ranger 4.0L Misfiring
I recently bought a used '01 Ranger with the 4.0L engine. I believe that it is misfiring quite a bit after it warms up. I've got the following DTCs.
P0171 - Fuel Trim
P0174 - Fuel Trim
P0300 - Random Misfire
I know the P0171, P0174 are common, but does the P0300 point to something specific?
Thanks in advance.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 11-09-2003, 10:39 PM
SurfinScott is starting off with a positive reputation.
It could simply be that you need new plug wires. If the ones on there are old, or you dont know cause you just bought it, buy a new set and see if the problem is solved. I had the same deal when I bought my 93 ranger. Got new wires and it ran great. if not, it could be old plugs, or maybe something bigger. good luck.
  #3 (permalink)
Old 12-13-2003, 11:03 AM
Update:
A hose to the PCV valve had a crack in it. I replaced it, reset the check engine light and that problem was solved.
I had other issues with rough idling and skipping. This was caused by excessive carbon buildup. It knocked out the MAF sensor. I had the engine "decarbonized" at the dealership and replaced the MAF sensor. Now it runs as smooth as ever. Gas mileage is better too.
FYI, I tried the DIY tricks of cleaning the MAF sensor and engine cleaning fuel additives. They did not work in my case.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
