Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 11-07-2003, 08:36 AM
Mike632 is starting off with a positive reputation.
Fan Clutch removal
Just a note on the removal of the fan clutch on a 2.9L engine. This is also a tip that works for many other engines.
I could not get enough friction on the pulley to loosen the fan clutch. I was almost resigned to buying the specialty wrenches. While surfing the net looking at different wrench sets I realized that I only had to:
1. Drill a hole into a piece of steel
2. Remove one bolt from the pulley
3. Bolt the steel bar to the pulley
4. The bar now rotates until it rests on the head of the next bolt
5. This locks the pulley in place and allows me to apply the necessary torque to loosen the fan clutch shaft.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 11-07-2003, 06:53 PM
markinms is starting off with a positive reputation.
Great tip!
Mark
__________________
1987 Bronco II, 4X4, M5OD 5sp
4.0L, HD Driveshaft, More to Come
Columbus, MS
  #3 (permalink)
Old 11-14-2003, 07:21 AM
reams is starting off with a positive reputation.
Outstanding tip.
Another way (that I have used and always work grate) is the Craftmen's "Strap Wrench" around the water pump pully. You'll have to remove the serpinteen belt and wipe off the water pump pully with a clean ragg. I've used this strap wrench on manny pullies and has never distorted or left mark one.
Thanks for the tip Mike632.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
